It is currently Mon Nov 09, 2026 0:12
PostPosted: Tue May 27, 2003 3:51
I recently aquired an extremely large LCD screen from an old Smith Corona Word Processor its a custom Epson LCD using the HD61200 Controller it has 6 of those ICs and 2 HD61203 ICs.. it is a large graphic Dot Matrix LCD - However, it only has 10 Pins anyone..? Help would be greatly appricated, thank you :?
-tap-
PostPosted: Tue May 27, 2003 4:03
the blue connection has 10 pins on it and on the PC pin 1 and pin 10 are numbered, the EL Light sits behind where the LCD meets the PCB
Just though I'd post these incase they'd be of some help..
-tap-
PostPosted: Thu Nov 30, 2006 0:00
************* REVIVING THIS DEAD THREAD!!!**********************
STILL WITH NO ANSWER... I pulled this giant LCD out of my cabinet yet again
to hopefully have some helpful wisdom told me so that I can carry on and use this wonderful LCD for my next up coming project..
Specs haven't changed. read above ^^^^^^^^^^^^^^^^^^^^^
-tap-
PostPosted: Thu Nov 30, 2006 11:46
Have you got any newer pics....links to old ones seem to be broken.
 Post subject: Pics to come
PostPosted: Fri Dec 01, 2006 0:49
i will take some pics tonight..
its a huge display approx 10.5"x3.5" the PCB itself is 11.24"x4.24" its graphical and has an el light... there is a contrast control on the pcb along with those controllers and a 10 pin out thing
on the board is printed "EPSON P300031100"
again sorry i will get pics up later tonight
-tap-
PostPosted: Fri Dec 01, 2006 1:42
Just so you are aware, the HD61200/HD61203 are row and common drivers, not the actual controller for the LCD. If it's only got 10 pins, it's quite possible that this used the HD61830 controller (which would have been in there with the LCD....possibly on a seperate board? ). The HD61830's have been replace with the LC7981, which is the same controller, just newer. I haven't seen anybody sell these controllers already made, but I have played with them and have made a few prototypes in the past. Not saying this is what drives your display, but it seems highly probable. Will see if I can dig something up on the net, otherwise you would have to start tracing connections back to the connector.
PostPosted: Fri Dec 01, 2006 6:17
I just realized i dont have a mini usb connector here for my pics :( i will have them by saturday but heres a list of every pic on the PCB:
HD61200 (6x)
HD61203(2x)
2902 JRC 973 (1x) ??
74HC163A(3x)
i don't mind doing traces because ihave the pin outs to the HD61200 and HD61203, it's just that those wires are under the glass ;/ i just don't like fucking around with the rubber pads because once you unalign them its sometimes a pain to get them back perfectly
-tap-
PostPosted: Fri Dec 01, 2006 10:12
tap wrote:
I don't mind doing traces because ihave the pin outs to the HD61200 and HD61203, it's just that those wires are under the glass
I meant tracing them with a multimeter :wink:
