It is currently Wed Feb 20, 2019 12:07
PostPosted: Sun Nov 16, 2008 3:05
such as ones with support for the ks0086 segment drivers?
i can get my hands on these displays for cheap, 320x240 with ccfl backlight and 4 wire resistive touch ! ( P/N : TM320240B )
i would like to build or buy a couple of controllers boards, inverters and if possible the resistive touch processors too
thanks!
PostPosted: Sun Nov 16, 2008 23:03
Is it maybe this display?
http://www.jyfd.com/1yjmokui/tianma/806 ... 20240B.pdf
That should work with the USB13700 for example if a PC interface is needed:
http://www.lcdinfo.com/products/usb13700.html
PostPosted: Mon Nov 17, 2008 19:56
yes, mine has the addition of a touch screen as well, but same display..
thanks for the link, do you know if that board could also hand the thouch?
PostPosted: Tue Nov 25, 2008 22:21
There is a small touch add-on board that can be used with USB13700:
http://www.skippari.net/projects/
Hopefully soon it will be fully supported also in the API.
