| any *current* info about controllerless lcd daughter boards http://forum.lcdinfo.com/viewtopic.php?f=6&t=2546 |
| Author: | omegatotal [ Sun Nov 16, 2008 3:05 ] |
| Post subject: | any *current* info about controllerless lcd daughter boards |
such as ones with support for the ks0086 segment drivers? i can get my hands on these displays for cheap, 320x240 with ccfl backlight and 4 wire resistive touch ! ( P/N : TM320240B ) i would like to build or buy a couple of controllers boards, inverters and if possible the resistive touch processors too thanks! |
| Author: | Henri [ Sun Nov 16, 2008 23:03 ] |
Is it maybe this display? http://www.jyfd.com/1yjmokui/tianma/806 ... 20240B.pdf That should work with the USB13700 for example if a PC interface is needed: http://www.lcdinfo.com/products/usb13700.html |
| Author: | omegatotal [ Mon Nov 17, 2008 19:56 ] |
yes, mine has the addition of a touch screen as well, but same display.. thanks for the link, do you know if that board could also hand the thouch? |
| Author: | Henri [ Tue Nov 25, 2008 22:21 ] |
There is a small touch add-on board that can be used with USB13700: http://www.skippari.net/projects/ Hopefully soon it will be fully supported also in the API. |
