| Need info on an LCD [TS35ND2501] http://forum.lcdinfo.com/viewtopic.php?f=6&t=2688 |
| Author: | dcahrakos [ Fri Jun 19, 2009 19:57 ] |
| Post subject: | Need info on an LCD [TS35ND2501] |
I was wondering if anyone knew what type of LCD is used in the GP2X F200 handheld device? I took it apart and there are no serial numbers or anything else to identify it with, I will upload a screenshot later on, need to wait for my cellphone battery to recharge before i can do that however. Any help would be appreciated as I would like to avoid buying an LCD for a project I am going to start working on if I can somehow manage to get this one working. Thanks. Edit: ok, so after a bit more searching and what not, I found out it is a Top-Sun TS35ND2501 3.5 Inch LCD. I will continue searching to see if I can find any documents on it or anything, has anyone had any experience with this lcd? edit 2: I found a document for it that explains the pin out and everything, should have done more searching before i posted this, but I would still be interested in finding out if anyone has had any experience with this LCD and any success in using it. |
| Author: | Henri [ Tue Jun 23, 2009 10:24 ] |
According to the datasheet I found here: http://www.fancyview.com/product/tft-lc ... 060321.pdf that looks like pretty standard digital input TFT panel. A display like this usually needs a relatively powerful LCD controller to drive it. So depending of the other parts in your project you might find it easy or then more challenging to drive the display. |
