It is currently Wed Jul 02, 2025 9:29
PostPosted: Mon Jul 13, 2009 0:19
Found a few of these... Seems that the resolution is a bit of an odd size.
What would I need in order to get one of these to work via USB?
640 x 350 Display NEW for $150 each!
I ask because I am going to be replacing a 640*480 LPT driven Planar, and I could only drive HALF of the screen... Will it be the same thing with the 640x350 display, or will I be able to drive the entire screen?
Hope that I can use the entire display w/ a USB interface... if not I have also purchased a 320x240 Planar. Henri do you know of a way to make one of these work?
PostPosted: Mon Jul 13, 2009 22:03
This display looks somewhat similar to the 640x400 model here: http://forum.lcdinfo.com/viewtopic.php?t=2579
It could be most likely made to work with that same USB controller board with suitable modifications to the controller timings. But for testing and making any necessary modifications I would need one of those displays.
