It is currently Sat Feb 22, 2020 21:35
PostPosted: Sun Aug 02, 2009 11:31
i have in my pososition 2 lcd's one came out of an old xerox fax machine and has the markings..
DATA VISION
PHICO D-0
9812 94V-0
P124-1
this model has 14 pins/wire coming out of it not 16 like the other models i think the extra 2 wires that i have found on other models are for the lcd backlight
i think that P124-1 is the model number and i understand that PHICO is the board manufacture not the lcd manufacture...
the other lcd is out of a handheld computer PCL-486 (just google it) anyways it is a SII (Seiko) lcd that displays 192x128 pixels and has the markings...
G191C21R0A0
I found a little bit of data on this one but the thing is that as i was typing the model number of this lcd in to the forum post box i noticed that if i pull the film/ribbon cable that covers the back of the board up a little more i noticed that the pinout is already stated (screen printed on the board) but any info on this board would still be helpful.....
i would like to make it so both can be hooked up to parallel port and i will convert them to usb.. but getting them to work is my main goal now!
ps hope that is enough data.... will post pictures soon
here is a link the the datasheet on the P124-1 http://www.dema.net/pdf/dain/DV-20200-S1FBLY.PDF
PostPosted: Sun Aug 02, 2009 12:41
pinout for the G191C21R0A0
pin 1 - D3
pin 2 - D2
pin 3 - FLM
pin 4 - M
pin 5 - CL1
pin 6 - CL2
pin 7 - D1
pin 8 - D0
pin 9 - VDD
pin 10 - VSS
pin 11 - VLC
pin 12 - F GND
pin 13 - VEL
pin 14 - VELG
I took the ribbon cable off it and installed pins in its place...
PostPosted: Sun Aug 02, 2009 14:16
Sigh....
again i found what i was looking for before anyone else could help but i will post the stuff i found because it is not easy to find...
the P124-1 is also called the DV-20200 and it is a HD44780-compatible lcd
and the pinout/ diagram to parallel is here, http://www.allspectrum.com/LCD-displays ... d44780.gif
that is the diagram for the 20208 but im fairly certian it is the same the only difrence that i see is that the 20208 has 20 pins and the 20200 has 14 but pins 15-20 are not even needed because pin 15 is that same as pin 1 and 16-17 are not used, pin 19-20 are the backlight, but the 20200 has no backlight :(
so it should work ill test it out and tell you how it goes
