It is currently Wed Nov 11, 2026 15:10
PostPosted: Sat Jul 26, 2003 16:48
A week ago i've picked up some old stuff from my companys garbage. There were two nice Optrex DMF5010 inside (T6963C), so I decided to get them connected to my PC via Parallel Port. The backlight (circuit included) is working well from my 5 V Power supply, but I seem to have problems producing the Vee Voltage. I've rebuild this circuit: http://www.lamepage.de/hardware/gfxlcd/ ... ly1.0a.png and it seems to work well. It is producing up to -27 V but the Poti can pull it down to -19. With a piece of software it was possible to view a clock on it, but only from a wide angle, not if i look straight onto the display. What may be the reasons for this? Is the supply to weak? On both of the displays there is a vertical line activated always - are they both damaged, or is this my fault?
TIA
Joeee
PostPosted: Sat Jul 26, 2003 19:53
I have to revise my problem: The man who made the schematic forgot to wire the reset via 10k to +, so my display could not show anything. My first results were asome rubbisch, but with system. Now I have the problem, that I have to change the contrast poti to every screen the display shows, so I think the circuit above is way to powerless.
PostPosted: Sun Jul 27, 2003 9:06
Yes, that sounds like a problem with the contrast circuit.
Users browsing this forum: No registered users and 55 guests
