| Help identify LCD from Epson CX8400 Printer http://forum.lcdinfo.com/viewtopic.php?f=6&t=2978 |
| Author: | runnerup [ Wed Apr 07, 2010 23:52 ] |
| Post subject: | Help identify LCD from Epson CX8400 Printer |
Hi, Does anyone have information on the LCD panel from Epson CX8400 Printer? Datasheet, controller etc? I don't even know the dimensions of this LCD, but its pretty big (used image editing software to "estimate" the size -- roughly 325x260). Chip on the back reads Epson E09A 81AA G7606. Couldn't find anything about this chip on the web. (Please see the attached pic.) I am guessing the chip on the back actually is a micro of some sort. I don't have access to any probing equipment Thanks, _Kyle
| Author: | jgray [ Tue Oct 26, 2010 8:17 ] |
| Post subject: | Re: Help identify LCD from Epson CX8400 Printer |
I recently pulled a color LCD from an Epson Stylus Photo R390. It is a 3.5" LCD, 320x240 QVGA. I found the service manual for this all-in-one printer/scanner and the pinout is below. Your LCD only has 9 pins, but may have similar signals. My LCD had numbers on the PCB and numbers on the Epson controller IC. I assume that they were in-house numbers, as I couldn't find data on any of them. I haven't tried programming my LCD yet, so I'm not sure of the proper method. At a guess, maybe the SDATA0-SDATA2 lines are to be loaded with successive RGB values, strobing the SCLK line for each one. If that is how it works, then this display would work like a raster CRT, painting each line until the screen is filled. This is purely a guess, however. If anyone knows different, please educate me. 1 - GND 2 - SCLK 3 - GND 4 - SCE 5 - SDATA0 6 - SDATA1 7 - SDATA2 8 - GND 9 - PNLRST (active low) 10 - +3.3V 11 - +3.3V |
