It is currently Mon Nov 09, 2026 4:58
 Post subject: Hitachi lmg7520rpfc
PostPosted: Sat Aug 02, 2003 18:35
Greetings.
There is a question.
Is present Hitachi lmg7520rpfc as it is possible to connect?
Beforehand thanks.
PostPosted: Mon Aug 04, 2003 12:20
Looking at the datasheet it looks like it needs external controller to drive it. It's a 320x240 display so I think SED133x might be able to drive it.
PostPosted: Mon Aug 04, 2003 18:45
Instead of you can prompt where it is possible to take a connection diagram.? 8O
PostPosted: Wed Aug 06, 2003 13:09
I think the best suggestion I can give you here is use google or some other search engine and try to look for external lcd controllers using SED1330/SED1335 or some other chip.
PostPosted: Thu Aug 07, 2003 18:18
Thanks but I not so understand in an electronics engineering therefore if there is a possibility to place links on schemes.
Thanks.
PostPosted: Fri Aug 08, 2003 22:30
Building the external controller board is not the simplest thing to do and might be difficult to get working. If you're not experienced with electronics I can't really recommend this option. Also building the board might cost more than buing a new display with controller.
Here's some controller board but this one also includes more functionality than only the controller:
http://www.angelfire.com/electronic/mic ... page8.html
I remember there was some german site about building your own SED1330 board but can't remember the url.
Also SED1330 datasheet probably has information what is needed to make the chip work with some lcd display.
PostPosted: Mon Aug 18, 2003 3:09
Hello
The german site is:
http://www.megas.org
there is a complete controllerboard for such displays ...
(costs around 50 EUR ...)
CU
 Post subject: Re: Hitachi lmg7520rpfc
PostPosted: Mon Aug 18, 2003 20:11
Dr.GuruCrash wrote:
Hello
The german site is:
This isn't the site I meant but it is a good link to add in this thread anyway if you can buy controller boards there. ;)
The site I meant had complete instructions and schematics for building your own SED133x controller board and also some information about 320x200 displays. Maybe I'll find it someday.
PostPosted: Wed Sep 10, 2003 20:10
Here's also something about building your own controller board:
http://www.lamepage.de/hardware/gfxlcd/index_de.html
