| How to connect Powertip PG12864 ARU-ANN-G ? [KS0108] http://forum.lcdinfo.com/viewtopic.php?f=6&t=319 |
| Author: | IFI_Mani.a [ Wed Aug 20, 2003 19:07 ] |
| Post subject: | How to connect Powertip PG12864 ARU-ANN-G ? [KS0108] |
Hi! I've got a Powertip PG12864 ARU-ANN-G. There are 3 Chips on the back: KS0108B, KS0107B and KS01???? (The Last Letters are destoryed). Here is the Pin-Assignment from the Manufactors Data-Sheet: Pin No. Symbol Function 1 VSS Power supply for logic GND 2 VDD Power supply for logic (+2.8~5.5V) 3 VO Operating voltage for LCD driving 4 D/I Register selection input High =Data register Low =Instruction register (for write) Busy flag address counter (for read) 5 R/W R/W signal input is used to select the read/write mode High =Read mode, Low =Write mode 6 E Start enable signal to read or write the data 7~14 DB 0~DB7 Data bus 15 CS1 Chip enable for D2 (segment 1 to segment 64) 16 CS2 Chip enable for D3 (segment 65 to segment 128) 17 RST Reset signal 18 VEE Power supply for LCD driving 19 BL+ Enable (on/off) for EL B/L 20 BL- No Now, my question is: Is this Display compatible to LCDInfo? And if yes: How do I connect this LCD to my Printer Port? |
| Author: | Henri [ Fri Aug 22, 2003 12:09 ] |
Yes it is compatible with LCDInfo. The pinout seems to be like here: http://www.skippari.net/lcd/ks0108.html But your display has EL backlight so you need to connect the pins 19 and 20 to inverter. RS means same as D/I for pin 4. |
