It is currently Mon Nov 09, 2026 2:25
PostPosted: Thu Aug 21, 2003 14:52
Hi!
i've wired my lcd just like the guides and plans i've found on this homepage. now i have the problem, that the display works not in "fullscreen" only a part shows data from the program.
i drawed it fast for better understanding *G*
so in the upper right part you can see a litte part of the actual screen (on the pic are some dots :roll: )
now i can't find a mistake. i've checked all cabels if every contact is right - nothing found. also the potentiometer and the backlight runs without problems.
so i hope you understand my problem and could help me!
THX
freezer90
PS: sorry for my bad english ;)
PostPosted: Fri Aug 22, 2003 12:05
Have you tried other LPT port settings in BIOS ? ECP/EPP often works fine but testing others shouldn't hurt.
Bad signal quality and wrong timing causes problems like this. For some rewiring everything with different cable has helped.
