It is currently Mon Nov 09, 2026 5:50
PostPosted: Fri Sep 05, 2003 15:16
I have this Display http://www.display-elektronik.de/DEM128064ASYH-LY.PDF (1,6 MB :!: )
I have connected it this way http://www.skippari.net/lcd/ks0108.html
My Problem is that i cant get any output on the LCD. The backlights are OK.
I have tried Liqiud MP3 too, but with it get get random Pixelerrors.
The KS108 testprogram doesn`t work too. It just freezes.
So is my Display not compatible with LCDinfo or is there another issue ?
I am using win2k sp2 an win 98. The LPT is on ECP.
My english is not the best one,but i hope i could explain my Problem.
PostPosted: Tue Sep 09, 2003 16:16
Your display should work just fine with LCDInfo and other programs supporting 128x64 KS0108 displays.
You can try these:
http://www.skippari.net/phpBB2/viewtopic.php?t=124
http://www.skippari.net/lcd/sekalaista/ ... lights.zip
http://www.skippari.net/phpBB2/viewtopic.php?t=121
http://www.skippari.net/lcd/sekalaista/ ... mation.zip
You could also try changing your parallel port mode.
PostPosted: Mon Sep 22, 2003 11:29
Thanks Henri.
After 2 weeks of searching i was finally able to fix my problem. It was a bad soldering on my Interface PCB which caused the problem.
Now my LCD works great 8)
Greets
F.C.
PostPosted: Mon Sep 22, 2003 11:31
Thanks Henri.
Greets
F.C.
