| Data Vision LCD with ks0108 chip how to? http://forum.lcdinfo.com/viewtopic.php?f=6&t=335 |
| Author: | fmcr [ Mon Sep 08, 2003 13:00 ] |
| Post subject: | Data Vision LCD with ks0108 chip how to? |
got this one, but have no ideia how to put it to work.. |
| Author: | Henri [ Mon Sep 08, 2003 14:47 ] |
Do you have a bare Datavision KS0108 display or do you have the complete Compsys serial module like in the picture ? |
| Author: | fmcr [ Mon Sep 08, 2003 15:18 ] |
just the display, and i think i hve to build the pcb and the cable but i don't understand electronics, well its time to learn, could you help me? |
| Author: | fmcr [ Tue Sep 09, 2003 10:56 ] |
is there any guide, how to make it??? help!! |
| Author: | Henri [ Tue Sep 09, 2003 15:56 ] |
The first thing to do is to check the exact model number of the display. It is often printed somewhere on the PCB or there might be a sticker with the model number. If you put the model number in google you can probably find a datasheet and there you can find the pinout and other needed information. Without more information about your lcd there's not much advice I can give you. |
| Author: | fmcr [ Tue Sep 09, 2003 20:10 ] |
this is what is witten on the lcd: Header: Data International Co., LTD then I'VE got a row of 3 chips: 1st - (SEC 748A) ks0108B 2nd - 12864-10 S2FBLY 97.47 009654 3RD - (SEC 746A) ks0107B ... under the chips: Phico D-0 94V-0 P77-3 Data Vision |
| Author: | Henri [ Tue Sep 09, 2003 20:27 ] |
Ok, so the model is 12864-10 S2FBLY Have a look here: http://www.skippari.net/phpBB2/viewtopic.php?t=170 http://www.skippari.net/phpBB2/viewtopic.php?t=76 |
| Author: | heathen [ Thu Jan 06, 2005 1:12 ] |
I have two of the same displays. Have to admit I'm completely new to LCDs but I'd like to get them up and going. Can you post the results from your experience with the display and any schematics used? I'm a little wary of just dripping solder on this thing until I'm sure what the pinout looks like. I've also looked at Henri's post here http://forum.lcdinfo.com/viewtopic.php?t=13&postdays=0&postorder=asc&start=0 for a Crystalfontz unit, looks similar... but is it the same? |
