It is currently Mon Nov 09, 2026 7:19
PostPosted: Tue Oct 14, 2003 22:52
ok I brought my self 1 of these.
16x2 BACKLIT LCD: Standard Hitachi chipset. Click HERE for data / pinout. Mounted on PCB with LED backlight, onboard piezo buzzer driver and a piezo transducer, microswitch, two colour LED and dual row 20 pin header with strain relief and front padding for panel mounted usage against a clear window.
and I soldered it the same as the table on this webpage
http://www.overclockers.com.au/techstuff/a_diy_lcd/
but mine is abit different and has 20pins and comes with its own cable (you can't plug it on to any thing tho) any way after I wired it and pluged it in all I get is the test screen and when I try to get it to display stuff with lcd Center 2.0 it dosen't work I have also installed DLPortIO.
Any Ideas??
