| i need help with setting up a Optrex DMF 5001NY-LY http://forum.lcdinfo.com/viewtopic.php?f=6&t=371 |
| Author: | byteme [ Wed Oct 22, 2003 2:09 ] |
| Post subject: | i need help with setting up a Optrex DMF 5001NY-LY |
i just bought a lcd (Optrex DMF 5001NY-LY 160x128 pixels) and i noticed it needed -21 VCC ?? where am i going to get that from(i think there is a -12v rail on my atx power supply).......i intend to set it up via parralel to my computer for a nice little display but....i need information before i even start the project here are the data sheets http://www.optrex.co.jp/us/product/catalog/pdf_dmf/5001ate.pdf...i what i want is more like a pinout and schematic on how to get the -21 VCC .................}------>could any one help ?? |
| Author: | byteme [ Wed Oct 22, 2003 2:15 ] |
btw i have also been through this site and the voltage doublers mentioned here are unavailable to me as i live in Perth,Western Australia as for the pinouts earlier mentiond by henri earlier........i dont really understand them...................aslo......i am a comlete NEWBIE at this |
| Author: | Henri [ Thu Oct 23, 2003 10:17 ] |
Few weeks ago I wired couple 5001NY-LY displays and I used two cascaded ICL7662 chips to make the negative voltage from +12V. ICL7662 costs about 3-4 EUR/pcs here in Finland and needs only few capasitors as external parts. I think you should be able to find something similar in Australia. As for the wiring I just followed the datasheet pinout but I guess I could draw somekind schematic of it. |
| Author: | Guest [ Thu Oct 23, 2003 17:59 ] |
ok..i will check that one out......kudos man..... one of my friend says i dont need -18 v just 23 volts cause the pda file dosent say any thing about it !!!!!!!! i know this might be to much to ask .......the best electronic store here in perth is called alltronics.........do u think any of their cmos ic's would work ?http://www.altronics.com.au/cat.asp?cat=2&grp=10&sort=code....and/or could i simply just use +23v for the VCC ? |
| Author: | Henri [ Thu Oct 23, 2003 19:40 ] |
You need the negative voltage. The datasheet just mentions the voltage difference needed. Like if you have Vcc of +5v and Vee of -20v then the difference is 25v. You can't use 23v for Vcc in any case. That would kill the display immediately. I guess this was a typo on your part. MC34063 could be one solution for your problem: http://www.altronics.com.au/cat.asp?cat ... 6&id=Z7250 Here is one schematic for -8v using the chip:
It should be possible to modify the resistor values to get higher output. And here's even a calculator for you that gives the needed component values when you give the input and output voltage wanted. http://www.nomad.ee/micros/mc34063a/index.shtml |
| Author: | Guest [ Fri Oct 24, 2003 11:20 ] |
acctually the 23v Vcc was out of my sheer stupidity..i sorryabout that (must have been a good laugh tho
Vout -18v Iout 30ma
Ct=NaN pF Ipk=160 mA Rsc=1.871 Ohm Lmin=NaN uH Co=NaN uF R1=5.6k R2=75k (17.99V) what does it mean when it says Ipk=160 mA and Rsc=1.871 ohm and what would i need to purchase from altronics (component shop) for this circuit and setting up my LCD |
| Author: | byteme [ Fri Oct 24, 2003 11:24 ] |
sori bout that i keep forgetting to log in.......i'll use cookies this time |
| Author: | Henri [ Sat Oct 25, 2003 13:01 ] |
For most of the component values you can take them from the -8v schematic. So it's for +5v input so you can then use the same +5v as for the lcd. Parts for -18v circuit: 1 x 16V 100uF capasitor for input 1 x 25V 100uF capasitor for output of course the capasitors can be of higher voltage rating 1 x 1,5nF capasitor 1 x 0,22ohm resistor 1 x 220uH 100mA inductor or something in the same range 1x schottky diode SB130, 1N5818, 1N5819, 1N5820 and the output voltage setting resistors for -18v: 1 x 5.6Kohm 1 x 75Kohm also you need a 10Kohm potentiometer or trimmer for the contrast adjustment. Hope I didn't forget much. |
| Author: | byteme [ Sat Oct 25, 2003 16:14 ] |
umm.....i thougt i needed -18v not -8v ?? |
| Author: | byteme [ Mon Oct 27, 2003 11:08 ] |
ok ignore that last post..... thanks alot!! byteme |
| Author: | Henri [ Mon Oct 27, 2003 22:38 ] |
I only saw models up to 15v in those and you need minimum -18v. But if these are suitable for negative voltages I'm not 100% sure. Datasheet mentions pins for -Vout and +Vout but also for -Vin and +Vin. I've seen similar modules which documentation has clearly indicated that they can be used for negative voltages though. |
| Author: | byteme [ Tue Oct 28, 2003 9:42 ] |
huh?? there was 1 converter that did up to +-24 volts http://www.computronics.com.au/meanwell/dke10/ that could be used but it is VERY EXPENSIVE costing $27.75 australian or about $20 Usd!!! but i would use that if it means no extra wiring or anything on the side........honestly i'd rather pay for simplicity than scrooge on complexity (which probbably means i'd screw it up:P) ByTeMe |
| Author: | Henri [ Tue Oct 28, 2003 21:19 ] |
I missed the DKE10 models when I checked the links last time. They should work fine with your display. I don't think $20 is that bad for a converter that allows you to forget about building the MC34063 circuit. You can save a lot of time. |
