| LCD graphic http://forum.lcdinfo.com/viewtopic.php?f=6&t=467 |
| Author: | spy1 [ Sun Dec 28, 2003 6:37 ] |
| Post subject: | LCD graphic |
Hello, I'm looking for a good LCD graphic (module size : about 110X40 mm). Do you know if someone can help me? Also, il would like to know if any linux driver has been written or I have absolutely to write one to control the LCD controller. Best regards Christian |
| Author: | Henri [ Tue Dec 30, 2003 1:06 ] |
How would you like to interface the module with ? PC I suppose as you mentioned linux ? Parallel port ? For parallel port you'd probably want a display with T6963C or SED133x controller. Should the 110x40mm size be for the picture or the whole module ? Some 240x64 modules might be in that range. Linux has some lcd software like lcdproc for example. You can find it from sourceforge. |
