It is currently Mon Nov 23, 2026 4:04
PostPosted: Fri Jan 02, 2004 0:37
Any have any info on the Epson EG2404Y-AR (256 x 64) graphic LCD module? They are available from All Electronics, but I am unsure what chip drives them etc...
TIA, :D
Iridium
 Post subject: EG2404Y-AR
PostPosted: Sat Jan 23, 2010 17:41
that graphic module is controllerless it needs to be run by a mcu,cpld,or a lcd controller chip . For this screen I think the sed 1330 chip is a good choice or try a pic or basic stamp to get it going.Admittedly the pic or stamp route will require some math calculations like the pixel clock and what not. Maybe investigating some of the chipps ont the back of the module will help you.U can do a continuity check on all the pins of the chips plus your connector header; that will at least keep you from frying the thing(I HOPE). My sugesstion is the sed chip unless ur comfortable with programming timing instructions on the mcu's
