| Sharp LM64P825 9.5" LCD from a Toshiba T2100 http://forum.lcdinfo.com/viewtopic.php?f=6&t=524 |
| Author: | Trigger [ Sat Feb 14, 2004 3:54 ] |
| Post subject: | Sharp LM64P825 9.5" LCD from a Toshiba T2100 |
Hey ppl!, I've got a Sharp LM64P825 9.5" LCD from a Toshiba T2100. but i can't find the proper datasheets for it I found one from a newer version (the LM64p858) the timing tables are all there But i don't know if i can use this datasheet for my LM64P825. And there is something attached to my LCD, a "FL Inverter" ( http://www.zeepost.nl/~triggs/LCD/1.jpg ). I found out it has something to do with the adjustment of the contrast, but i don't know the exact purpose of the ua0392p01 NJD4185. Maybe some of you ppl know what it's for Some links Datasheet: http://www.zeepost.nl/~triggs/LCD/lm64p858.pdf FL Inverter: http://www.zeepost.nl/~triggs/LCD/1.jpg LCD typenummers: http://www.zeepost.nl/~triggs/LCD/2.jpg Complete lcd: http://www.zeepost.nl/~triggs/LCD/3.jpg Pins: http://www.zeepost.nl/~triggs/LCD/4.jpg I hope some of you ppl know a bit more about the FL inverter or can get a datasheet for the LM64P825 LCD. Thanks in advance!! |
| Author: | whypick1 [ Sat Feb 14, 2004 5:57 ] |
Good luck. The problem with screens that big is that they usually come with no standard controller, the host device drives the display. There's no exception here, as your display is controllerless (as indicated on page 6, anytime you have to feed a clock signal, it's controllerless). Controller boards are very expensive, and building one of your own requires some deep understanding of timing characteristics and other boring stuff, not to mention lots and lots and lots and lots and (get the picture) SMD soldering. |
| Author: | Trigger [ Sat Feb 14, 2004 11:27 ] |
whypick1 wrote: Good luck. The problem with screens that big is that they usually come with no standard controller, the host device drives the display. There's no exception here, as your display is controllerless (as indicated on page 6, anytime you have to feed a clock signal, it's controllerless). Controller boards are very expensive, and building one of your own requires some deep understanding of timing characteristics and other boring stuff, not to mention lots and lots and lots and lots and (get the picture) SMD soldering.
I do have the capabilities to make my own controller... and i dunno why i should do SMD soldering.. ? (not that i can't because i have access to a SMT-lab). I just need some more information The datasheet i've got has the most important information.. but i dunno if i can use it for my LCD |
| Author: | Henri [ Sat Feb 14, 2004 16:17 ] |
The inverter powers the backlight of the LCD. I don't know if the datasheet matches your display but the model numbers are close so your chances are good I believe. And often these kind lcd's have same connections and are driven the same way so if you know the pinout you should be able to connect the controller. As for the controller you should have the needed information/timings in the display datasheet so just figure out a circuit that clocks some data from some memory to the display at the correct timing and you should have your controller. I'm sure many are interested in this so it would be great if you'd keep us updated of your progress. |
| Author: | Trigger [ Sat Feb 14, 2004 22:56 ] |
the datasheet i currently have does not match any of the LCD's pinouts 2bad |
| Author: | Silversky [ Wed Feb 25, 2004 21:33 ] |
| Post subject: | Some info about graphical displays'n controllers |
lcd-controller info to begin: http://www.hantronix.com/down/3224app.pdf many controller chip manuals: http://www.gaw.ru/html.cgi/txt/lcd/chips/ many lcd pinouts: http://www.eio.com/datashet.htm lcd-controller for printerport: http://www.lamepage.de/hardware/gfxlcd/index_de.html (http://babelfish.altavista.com/ to tranlate it) make your own 8-bit lcd-controller for isa-bus (sed 1330SED1335/SED1336 ): http://iris.elte.hu/~dave/lcd.html more code for sed1330: http://navi.cx/svn/picogui/trunk/pg1/se ... /sed133x.c |
| Author: | dreadie [ Tue Apr 13, 2004 0:39 ] |
Best bet is to check out www.mp3car.com forums, they usually hook up a ton of LCDs, there are a few controllers such as a Datalux and a few others (i personally have a Fraker controller driving my Sharp 10.4" LQ10d367 display). Too bad that isnt an LVDS panel, as I have a LVDS controller with all cables and inverter, but your screen isnt LVDS. I will see what I can find out about your LCD, but sharps general used the same pinout on a ton of panels. |
