| Optrex DMF-50316N Connection? http://forum.lcdinfo.com/viewtopic.php?f=6&t=542 |
| Author: | Dumbotron [ Sun Feb 29, 2004 4:33 ] |
| Post subject: | Optrex DMF-50316N Connection? |
OK, I give up. Three hours of trying to find a lpt port wiring schematic for this thing is enough. Can any of the schematics posted prev. in the forums be applied to this particular display? It has a T6963C-0101 as per the data sheet with a ccl backlight with male 4 pin molex and 20 pin header in two rows of 10. I know how to solder, don't know jack about LCD's! Thanks for any help. http://www.optrex.com/engcenter/manuals.asp |
| Author: | Henri [ Tue Mar 02, 2004 13:58 ] |
The pinout seems to mostly match the one here: http://www.skippari.net/lcd/t6963c_schem.html The exception I saw is INVERT function in pin 20. If you connect it to +5v you get inverted picture and if you connect it to ground you get normal picture. DMF-50316N also has CCFL backlight and needs CCFL inverter to power it. |
| Author: | Dumbotron [ Tue Mar 02, 2004 19:55 ] |
| Post subject: | Thanks |
Thanks for the information Henri. I'll give it a try using that schematic. I just wonder what color the smoke will be.... |
| Author: | paulk501 [ Fri Aug 04, 2006 4:25 ] |
How did it go??? I also need help with this display
| Author: | One~Zero [ Fri Aug 04, 2006 12:12 ] |
What exactly did you need help with? |
| Author: | paulk501 [ Fri Aug 04, 2006 14:48 ] |
i need to know if the pinout even worked and im gona need help backlighting it because the ccfl is dead. thats what i was told EDIT: ive got one of these also and dont know where to start.
| Author: | coorz [ Fri Aug 04, 2006 19:27 ] |
For the the Optrex 240x64 you can use any T6963C to LPT wiring scheme, for example this one. Hook up the CCFL to a modding CCFL Tube inverter and check that, if it's dead then it might be near impossible to find a replacement. Since the diffuser is already in place you could try it with some LEDs. Your second LCD looks kinda harder to hook up, you'll need datasheet. |
| Author: | Michael [ Sat Aug 05, 2006 19:13 ] |
That second LCD looks as if it's controllerless and the chip which can be seen may actually be one of the driver chips, perhaps the row driver. |
| Author: | paulk501 [ Mon Aug 07, 2006 22:13 ] |
coorz wrote: For the the Optrex 240x64 you can use any T6963C to LPT wiring scheme, for example this one.
Hook up the CCFL to a modding CCFL Tube inverter and check that, if it's dead then it might be near impossible to find a replacement. Since the diffuser is already in place you could try it with some LEDs. Your second LCD looks kinda harder to hook up, you'll need datasheet. the optrex screen after i wire this up what program would i use on my pc |
