It is currently Fri Nov 06, 2026 9:14
PostPosted: Sun Mar 07, 2004 17:57
looking for ANY info about this dislpay, it has 8 pins, i guess they are:
1 - LCDRSTX - Reset
2 - VOUT - DC/DC voltage converter output
3 - Gnd (0V)
4 - LCDCSX - Chip select input
5 - LCDCDX - Control/display data flag input
6 - SDA - Serial data input
7 - SCLK - Serial clock input
8 - VBB - Suply voltage
but what i don't know the rezolution (96x60???)
what Chip On Display ?? smth like this: pcd8544 ???
HELP , ANY INFO 8O
PostPosted: Sat Mar 13, 2004 11:51
I don't know anything about this display but the pinout looks very similar to the nokia phone displays using PCD8544. You could try it with the LCDInfo PCD8544 driver to see if it's PCD8544 or some other Philips controller with compatible command set.
