| flickering output at all after startup lcdinfo http://forum.lcdinfo.com/viewtopic.php?f=6&t=648 |
| Author: | Karel [ Sat May 08, 2004 15:52 ] |
| Post subject: | flickering output at all after startup lcdinfo |
hi, I tried a new display today and is a mgls24128-HT-G with a hd61830 controller. I wired it and with power on all the pixels light up but after I start the lcdinfo the whole screen flickers in a strange sequence. The same happens with liquid mp3. The power is according to the datasheet but I can't seem to find the problem. Does someone have an idea how to debug this thing? |
| Author: | Henri [ Wed May 12, 2004 22:57 ] |
I think you should check your wiring. And also make sure you have the wiring config in LCDInfo set correctly. HD61830 flickers when it's not yet properly initialized. |
