It is currently Fri Oct 09, 2026 7:37
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Sun May 23, 2004 11:03
I'd like to try connecting my Nokia 5110 LCD with my parallel port, but I lack an schematic to do so. Can anybody help me with a link/image?
Thanks in advance
PostPosted: Mon May 24, 2004 22:36
I know people have used 5110 lcds with LCDInfo using this schematic:
http://www.skippari.net/phpBB2/viewtopi ... =2456#2456
Only difference with 5110 display should be the Osc pin which was mentioned here:
http://www.skippari.net/phpBB2/viewtopi ... =2522#2522
The 9 pin pinout for 5110 display should be this:
http://www.skippari.net/phpBB2/viewtopi ... =2455#2455
PostPosted: Mon May 24, 2004 23:40
Henri, thanks for the reply. However, I still have some doubts (I'm sorry, but I want to fully understand this). Osc pin from the LCD must (or so I think) be connected to a PCD8544, however, no 8544 is present in the schematic:
or this schematic (very similar, but instead of using an embedded chip to convert logic voltages, uses R's and Zener diodes):
I may be doing a wrong assumption, which is that the right side pins on your schematic are not connected directly to the LCD, but to PCD8544, and then there would be several connections between PCD8544 and LCD (as stated in the PCD8544 .pdf sheet). I was making this assumption after reading a french tutorial about making 3310's screen work with LCDINFO without using PCD8544.
http://users.skynet.be/fa358153/david/t ... /index.htm
According to this article, it is possible to do it without PCD8544. I was wondering what would happen if LCDinfo could use one of the LPT port pins to output a 32Khz clock signal... could 5510's LCD be used as in the french guide?
Again, I thank on advance any tips or guidance that anybody can give.
PostPosted: Tue May 25, 2004 17:17
No problem, better ask if something is not understood.
There's no separate PCD8544 controller but rather the chip is on the lcd glass. It's the dark rectangular chip next to the connector.
The signal names in the schematic are meant to be directly connected to the corresponding display pins.
So it's not possible without PCD8544 as that's the controller LCDInfo interfaces with and also PCD8544 is integrated in the display.
You should not need to feed 32Khz signal to the Osc pin as according to the PCD8544 datasheet connecting the Osc pin to Vdd (V+ in the schematic) enables the onchip oscillator.
Hope this clears some things.
PostPosted: Tue May 25, 2004 19:23
Henri, thanks a lot for clearing that up for me. I'll post with results once I try this.
PostPosted: Tue Jun 08, 2004 22:20
http://serdisplib.sourceforge.net/ser/pcd8544.html
This page show how to connect 5110 display without chips.
Can lcdinfo use this way to connect lcd to lpt?
This how i did it
Another 5110 is for powersuplu purposes only.
PostPosted: Wed Jun 09, 2004 16:02
Basically that is very similar to the way presented here in this forum. It is just using only resistors on the data lines and no level converting IC. There seem to be some differences in the order the signals are connected to LPT port but if they are changed to match the schematic presented here it should work fine with LCDInfo. It is also using external power but that shouldn't matter.
PostPosted: Wed Jun 09, 2004 23:04
Got mine to work, finally.
using 2.8v zener on pin 7.
lpt-lcd
2-2
3-3
4-9
5-5
6-4
25-7
1K resistors on lcd pins 2,3,4,5 and 9
PostPosted: Tue Jun 29, 2004 14:08
I have managed to get a screen from a nokia 5110 but I can't get it working...
Kalamake ar you using only one zener? On the image there seems to be 6 zeners used. And have you used capacitors?
And...what is the best way to connect the wires to the lcd? I used the original plate from the phone but since I messed a bit to much, the connections may not work anymore... I thought about soldering the wires directly to the lcd but the connector seems to be made of rubber so that's no sollution...
thx,
Frost.
PostPosted: Wed Jun 30, 2004 6:13
Hey All, for those who are interested ive written a program (only beta-1) to display a string of text onto one of these displays using SerDispLib.
enjoy.
It's a simple program which is run from the linux command line.
Ps: I will be updating it very soon.
[url]c47.no-ip.org/lcd-beta1.tar.gz[/url] *hosted on my webserver, so dont expect an extremely fast download.
PostPosted: Sun Oct 17, 2004 12:40
thx,
Frost.
I did testi, one zener, no other components!!!
zener between lpt pins 7 and 25
pin 7 on lpt to pin1 on lcd
Maybe display might get broken, but if shit happens, buy new display and put resistors.
 Post subject: Program..
PostPosted: Mon Feb 13, 2006 17:09
Hi, I would like to test the display I have.
I was trying to control the display with a microprocessor but as I got no results yet I may have burned the display controller.
Can anyone send me a program that already controls the display through Computer Parallel port or a piece of code? This way I can asure of it´s condition.
Thanks!
Best Regards,
Henrique
Henrique Vilela
rickonvb@yahoo.com.br
PostPosted: Mon Feb 13, 2006 18:43
http://oms.wmhost.com/lcd/NokiaMonoLCD.zip
This should work (opens only a console window without displaying anything in it, and quits with esc) displaying a tiny effect on the screen.
How to wire the LCD to LPT port:
1 - SDA
2 - CD
3 - Reset
14 - SCL
If your LPT port is older 5 volts type you need to buffer the signals or you'll fry the controller. With newer 3.3 volt ports you can wire it directly.
 Post subject: Hi
PostPosted: Mon Feb 13, 2006 22:19
Hi Zee.. I have these pins on the Display:
VDD
SCK
SDIN
D/C
SCE
GND
VOUT
RES
1) I may I have 2,7 to 3,3V on VDD, right? I´m a little confused but how much current do I need from the source?
2) CD = D/C (Data / Command), correct?
3) Reset = Res
4) SDA = ?
5) SCL = SCK? Clock?
I need all the pins wired up, don´t I?
Best Regards,
Henrique
Henrique Vilela
PostPosted: Mon Feb 13, 2006 23:17
I used one of the remaining datalines (4-9) for the VDD.
So it would go:
LCD - LPT
VDD - 4
SCK - 14
SDIN - 1
DC - 2
SCE - 18-25
GND - 18-25
VOUT - Connect to GND through a small capacitor.
RES - 3
Users browsing this forum: No registered users and 95 guests
