It is currently Wed Nov 04, 2026 18:24
PostPosted: Wed Jun 02, 2004 11:58
Hi there, I've found some VFD's ans I'd lie to use them, but I don't know at all how to plug them and witch soft I can use to control them. :cry:
The Two models I own
-The first, FUTABA model M202SD08G
Some pictures :
The front
In TEST mode (pin16 @ LLv)
The PCB
Here you can see the datasheet I've found :
http://aflb.com/images/neXus/VFD/anne2242.pdf
-The second, Noritake ITRON CU20025ECPB-U1J
Pictures :
The front
PCB face
DATASHEET(a very minimal datasheet :( ) :
http://aflb.com/images/neXus/VFD/CU20025ECPB-W1J-03.pdf
So, I'd like to know if they are compatible wirh LCDinfos or something else to use them to monitor temp, speed....
If someone could help me, that could be great !
(scuse 4 my poor english, I'm french and it's the morning... :p) :roll:
PostPosted: Wed Jun 09, 2004 15:43
It seems the Noritake U1J would be HD44780 compatible or at least close.
The Futaba doesn't seem to be compatible with anything I would have recognized. But all the data was in the datasheet so it shouldn't be that difficult to write a program that would drive it.
