It is currently Wed Nov 04, 2026 20:24
 Post subject: Help on KS0108
PostPosted: Fri Jun 04, 2004 1:05
I received 2 LCD with Dual KS0108 Controller. (128*64)
I have fallowed this schema
So far, I have data. LCDinfo and Liquid-MP3 are working correctly,
My problem is with the Backlight. It simply don't work.
I looked many time to my connection, but it just don't light up. I tried both LCD, and both have the same problem.
My LCD is from Wayton M.I.T. and look like this when it work :roll:
thanks for help
PostPosted: Fri Jun 04, 2004 4:13
Well I found the problem.
On that type of LCD, the VCC and Ground on Pin 19 and20 are inverted (so VCC should be on pin 20, not 19 :roll: )
PostPosted: Fri Jun 04, 2004 13:59
I recognize that LCD from E-Bay. Anything useful electronics on the rest of the PCB?
PostPosted: Fri Jun 04, 2004 14:24
yes I got it from Ebay
on the PCB, you can get the 10k Pot for contrast (small & usefull)
Switchs are electronic, so if you can use it.. I need mecanic Switch for my project... There is also a bigger switch like you find on Computer for on/off
The rest is simple LED
You need to fallow the Schema if you want to hook it up, except you change de polarity of the Backlight AND put a 22Ohm Resistor isted of 1.5ohm (which is too low, anything from 5 to 25 is fine)
