It is currently Fri Nov 06, 2026 18:44
PostPosted: Wed May 26, 2004 13:43
Hy. I bought an Powertip PG-12864A and an Toshiba TLX-1391-EO(128x128). On the Toshiba display the controller is T6963c but on Powertip i'm not sure. The info is unreadable. Perhaps I can get some hints from you on connecting them to paralel port and if your software can suport these controllers.
Thank's.
PostPosted: Tue Jun 15, 2004 17:23
http://www.dutchgamerz.net/powerlcd/pages/LCD_Connection.htm
PostPosted: Wed Jun 16, 2004 20:35
I think the Powertip PG-12864A might use KS0108. If you find the datasheet it should have this info and also the pinout.
Search found this:
http://www.skippari.net/phpBB2/viewtopi ... t=pg12864a
So I guess you could use that schematic. But you should still find the datasheet and confirm that the pinout matches the one in the schematic.
PostPosted: Wed Jun 16, 2004 20:46
And some info for the TLX-1391:
