| HELP !!! Wiring wg240128a-FFH-VZ http://forum.lcdinfo.com/viewtopic.php?f=6&t=735 |
| Author: | CryoFast [ Wed Jun 30, 2004 23:20 ] |
| Post subject: | HELP !!! Wiring wg240128a-FFH-VZ |
I'm wire what Henri said on his site in T6963-schematic, but I don'tsee anywhere on my lcd .... Anybody help !!! My LCD had build-on negative invertor (-16V) |
| Author: | AmigaMentor [ Sat Jul 03, 2004 3:09 ] |
| Post subject: | Re: HELP !!! Wiring wg240128a-FFH-VZ |
CryoFast wrote: I'm wire what Henri said on his site in T6963-schematic, but I don'tsee anywhere on my lcd .... Anybody help !!!
My LCD had build-on negative invertor (-16V) Is that your LCD ? http://www.mostron.de/pdfs/pdfgraphic/WG240128A.PDF |
| Author: | Henri [ Mon Jul 05, 2004 11:22 ] |
So you got all dark display or nothing at all ? Maybe if you presented all your connections here we could check if there was anything that might be wrong. |
| Author: | CryoFast [ Mon Jul 05, 2004 15:35 ] |
AmigaMentor Yes it is !!! Henri Quote: So you got all dark display or nothing at all ?
nothing at all I'm check my connctions, but it don't wrong .... LPT LCD 1 5(WR) 2 11(DB0) 3 12(DB1) 4 13(DB2) 5 14(DB3) 6 15(DB4) 7 16(DB5) 8 17(DB6) 9 18(DB7) 14 7(C\E) 16 8(C\D) 17 6(RD) +5V 3(Vdd),19(FS),10(RESET) GND 2(GND) --------- 9(Vee) | --- 10K <------4(Vo) --- | -------- GND |
| Author: | Henri [ Wed Jul 07, 2004 12:20 ] |
If you can't even adjust contrast you might not have enough contrast voltage. You could try connecting the other end of the contrast potentiometer to +5V instead of GND. How about the REVERSE pin ? Try connecting it to +5V or GND. |
| Author: | CryoFast [ Thu Jul 08, 2004 11:51 ] |
Henri wrote: If you can't even adjust contrast you might not have enough contrast voltage. You could try connecting the other end of the contrast potentiometer to +5V instead of GND.
How about the REVERSE pin ? Try connecting it to +5V or GND. Now I can adjust contast !!! I'm connect 20pin(REVERSE) to +5V and it work !!! But I'm see garbage on my screen ( i mean my LCD connecting wrong ? ) maybe connect LCD like this : LPT -> LCD 1-----7(C\E) 2-----11(DB0) 3-----12(DB1) 4-----13(DB2) 5-----14(DB3) 6-----15(DB4) 7-----16(DB5) 8-----17(DB6) 9-----18(DB7) 14-----6(RD) 16-----5(WR) 17-----8(C\D) +5V------3(Vdd),10(RESET),19(FS),20(REVERSE) GND-----2(GND),1(FG) |
| Author: | CryoFast [ Fri Jul 09, 2004 13:33 ] |
Henri I do it !!!! All works !!!! I'm check my connections and find bad contact between LCD - LPT !!! P.S. I can post you my shematic to wire my LCD ( and photo too ). |
