It is currently Sat Nov 14, 2026 4:28
 Post subject: KS0108 dead ?
PostPosted: Sat Jul 10, 2004 22:47
I have2 KS0108 LCD
One is working correctly for few weeks.
The Other is working only on the left side. Half of the display look dead.
I remade all my connection over again, and no matter how, it look just plain dead.
Is there anything I could do ? or someone can explain me how the CS2 controller could become dead ?
This LCD worked for about 1 week then died..
thanks
PostPosted: Mon Jul 12, 2004 11:15
If nothing else has changed and all wiring is still fine the conclusion could be that the controller is dead for some reason.
I have also one KS0108 display that has the other controller dead. The reason this happened was that I did something stupid when putting the display together and then forgot it there. The display then worked fine for about a year but one day when I again plugged it in there was this smell you don't want with electronics stuff and very hot controller IC's on the back of the display and then other controller was dead.
 Post subject: LCD,
PostPosted: Thu Jul 29, 2004 4:59
I thinks you may check follow.
1. wire connection is fine ? Not only CS2, RS RW and E to second KS0108
also important.
2. ESD kill the second Ks0108
PostPosted: Mon Aug 02, 2004 17:18
ESD ??
I redid all my wiring on a circuit and got the same result, it's plainly dead :cry:
PostPosted: Thu Aug 05, 2004 15:19
ESD == ElectroStatic Discharge
