It is currently Tue Nov 03, 2026 9:39
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Wed Aug 25, 2004 23:53
I´m looking for aprox 240x128 lcd with orange or red on black colouring. I´m building a car mp3 player and that display comes to it.
Is there any alternatives than noritake´s vfd´s?
thanx
PostPosted: Thu Aug 26, 2004 15:34
coorz has a n1 one...but i dont know where he get that from ?
PostPosted: Thu Aug 26, 2004 17:28
There used to be a shop in Netherlands that sold colored graphic LCD's. But it appears they're gone now; www.modwarehouse.nl
I'd go for a VFD as i doubt any LCD would have a good enough contrast and decent viewing angle to be used in a car.
PostPosted: Mon Dec 13, 2004 6:54
If you get a standard White on Black LCD, you can very carefully pull the display off the PCB, and put a colour filter (celephane) behind the lcd, this would change the LCD to any colour you would like.
PostPosted: Mon Dec 13, 2004 8:31
That works? Hmmmmmmmmmmm.
PostPosted: Tue Dec 14, 2004 0:00
There's no reason why it shouldn't...
To tell you the truth... not 100% sure. I've never tried it, it's only a theory. It won't work on LCD's that have no backlight though, as they usually just have a reflective surface glued right on the LCD. But anything that has a clear LCD when you remove it from the frame, you should be able to do something similar with. LED backlighting would affect the colour though, as LED backlighting is usually green or yellow. If you really wanted a red and black one, you could also change the LED backlighting to red surfacemount LED's... I've done it before with Mobiles phones, but you have to be really good at soldering surface mount technology.
I'll test it and get back to you. ;)
PostPosted: Tue Dec 14, 2004 0:11
Ok... Quick update...
The green coloured LCD might actually have that green colouring in the glass itself... So, They are out, Unless.... You want to create an orange colour, by putting a yellow colour between the LCD and backlight...
Experiment I guess... I'll keep you updated as I play more. :)
PostPosted: Tue Dec 14, 2004 5:10
OK.... So I experimented a little myself... a whole of about 2 hours, and 30 mins of that was getting the display I was going to pull apart wired and running with LCDInfo.
This is before any playing, with just it running.
For those of you that have no idea how to pull apart an LCD.
Ok... Now this has 2 differant coloured celephane, a yellow on the right, and a reddy pink on the left. as you can see, the yellow didn't seem to make much of a differance, however if you layered a few sheets together, you might get a nice orange. The reddy pink colour looks more like a brown.
Another alternative if you wanted to do a permenant change, would be to remove the LED back light, and spray it with a clear type glass paint. This would give it a much better uniformity as the celephane gives a rippled water effect under the LCD glass.
Anyway, happy playing. ;)
Oh, and thanks KrAkKen. ;) You know what for. ;)
PostPosted: Tue Dec 14, 2004 7:28
OK... Just to prove it can be done... here...
Here's the original... This is a Nan-ya 240x128 with CFL backlighting. The screen is inverted so that it's white on black.
And here's the same LCD after a VERY simple modification.
If you look closely you can even see where I didn't cut the celephane quite right, and the white is still showing through.
My camera is a crappy camera too, so it doesn't really give it justice.
PostPosted: Tue Dec 14, 2004 9:32
That's some decent results. I know a German shop that sells QVGA displays in various colors based on this same principle.
In a car you'd really need a native colored display with a good viewable angle and contrast. A VFD would be ideal :wink:
PostPosted: Tue Dec 14, 2004 23:44
Coorz,
I agree with you there, a VFD would be the best option by far, Well... other than an OLED... although, I would like to see a comparision. Got a nice demo VFD here at work, would love to get my hands on it.
PostPosted: Wed Dec 15, 2004 0:20
A big one ? :D .
I've yet to see an OLED bigger than 128x64.
PostPosted: Wed Dec 15, 2004 22:13
Nice to see some life in this thread.
The startting problem is solved. I found quite a nice lcd from ebay, it's 480x240 planar El display. That's exactly the colour what I have looked for. In real the colour is almost orange but camera distorts the colour so in pictures it looks yellow.
PostPosted: Wed Dec 15, 2004 22:52
8O please let us know how you interfaced it. We got the same Planar 480 too but on the SED1335 it's worthless :cry:
And yes that would be ideal for car use, if you can find the 320x240 HB version, that one is even brighter than the 480.
PostPosted: Wed Dec 15, 2004 23:36
Nice to see someone else's desk looks like mine. ;)
Nice display... very nice... I take it, it's also a nice hi-res small dot pitch also? 8O
Now I'm jealous... :D
