| IEE VFD 4x20 03601-90 http://forum.lcdinfo.com/viewtopic.php?f=6&t=853 |
| Author: | Truzzone [ Thu Sep 30, 2004 18:36 ] |
| Post subject: | IEE VFD 4x20 03601-90 |
Hi, the vfd photos [click on the photos for zoom]:
I find this datasheet. I wiring the vfd with this schematic from VFDWorld
I run LCDInfo (0.6 build17), configure to HD44780 4x20 and only in 8 bit mode I see a strange characters (only characters are alternated by two space) and when I close LCDInfo I see in the end of vfd 'Goodbye Bye!' The vfd are wiring correctly? Is it compatoble with HD44780? What I do for work correctly the vfd? Truzzone |
| Author: | Henri [ Wed Oct 06, 2004 17:27 ] |
Sounds that either the VFD isn't HD44780 compatible or then the timings of the LCDInfo HD44780 driver don't work with it. There was also some other reports of another VFD that was supposed to be HD44780 compatible not working correctly with the driver. |
| Author: | Truzzone [ Wed Oct 06, 2004 17:57 ] |
I try with other program for lcds: lcdsmartie and with jalcds I see a charapters similar to the word I digit in the software, for example 'hello hello' in the display I see 'hègo ùelòo' Truzzone |
| Author: | Henri [ Sat Oct 09, 2004 11:46 ] |
Have you done any programming ? It might help changing the timings in the driver. Maybe I could also try doing this but experimenting would be easier for you as you have the real hardware to test. |
| Author: | Truzzone [ Sat Oct 09, 2004 14:31 ] |
If you are think it is only the timings, I know a little of programming and I have a friends that programming from 2/3 year in delphi and c. Whichever help are welcome Truzzone |
| Author: | Henri [ Sat Oct 16, 2004 12:56 ] |
You can find the latest LCDInfo HD44780 driver sources here: http://www.cme.co.za/rudi/downloads/hd44780_driver.zip It is mostly the WriteData() and WriteCtrl() functions that could be experimented with to try if different timing could help. Some delays could be added etc... |
| Author: | Truzzone [ Fri Oct 29, 2004 16:22 ] |
Hi Henri, please send me a pm or email with your address for send one of my vfd for gift if you have the time for fuction with your LCDInfo Truzzone |
| Author: | bbiandov [ Sun Jan 29, 2006 11:08 ] |
I have the same VFD and it works with another little program: http://vfdworld.com/index.php?page=download Not sure if it will work with LCDinfo but it defenitely works with this application. ~B |
