It is currently Sun Oct 04, 2026 9:01
PostPosted: Wed Oct 26, 2011 13:18
Dont know if you guys can help but here goes...
I have 2 LC79430 based LCD's - yes from ebay! - here
http://www.ebay.co.uk/itm/300549241743? ... 1439.l2649
They are new LC79430 and LC79401 based. Model EDT EW50107FLYU 320x240
Pinout is as follows:
1 vo (interestingly, pin 2 and 3 dont adjust contrast with a pot or with -18v applied to vee and the pot connected)
2 vee
3 D3 to 79401
4 D2 to 79401
5 D1 to 79401
6 D0 to 79401
7 gnd
8 +5
9 CL2 to 79401
10 CL1 to 79430
11 FLM (DIOB0)
12 LED K
13 LED A
14 NU
Looks like 'm' is generated on board
I am using an atmega 88 so I can change the timing parameters of the timings.
My program works and LCDstudio works with another 320x240 LCD I have but with on board SED.
However, both progs give me a display on the new LCDs with a bought external board with the sed on it but it is as if the framing is too fast on it. I can see the x clocked data displayed in the correct x column but it is all down the screen (as if vertical hold is lost).
I have tried various initialisations in my program (lcdhype and lcdstudio wont allow display timing changes )
The current settings I use to init the sed are as follows (I am changing command &H40 P4, P5, P6 and P7 when I try setting up the display):
Call Lcd_send_cmd(&H40)
Call Lcd_send_data(&H30)
Call Lcd_send_data(&H87)
Call Lcd_send_data(&H07)
Call Lcd_send_data(&H27)
Call Lcd_send_data(&H55)
Call Lcd_send_data(&Hef)
Call Lcd_send_data(&H28)
Call Lcd_send_data(&H00)
Call Lcd_send_cmd(&H44)
Call Lcd_send_data(&Hf0)
Call Lcd_send_data(&Hb0)
Call Lcd_send_data(&H04)
Call Lcd_send_cmd(&H4c)
Call Lcd_send_cmd(&H5a)
Call Lcd_send_cmd(&H5b)
Call Lcd_send_data(&H01)
Call Lcd_send_cmd(&H59)
Call Lcd_send_data(&H10)
Call Lcd_send_cmd(&H5d)
Call Lcd_send_data(&H4c)
Call Lcd_send_cmd(&H46)
Call Lcd_send_cmd(&H42)
Sorry this is long winded, I know the sed can work with these chips from seeing other datasheets but I dont know what I am doing wrong....
Any help / pointersd appreciated.
PostPosted: Thu Oct 27, 2011 9:31
All Sorted! I had FLM connected to WF instead of YD and didnt realise I needed a -ve voltage on VEE - 3 x 9volt batteries proved that worked ok!
dicky
Users browsing this forum: No registered users and 296 guests
