| Seiko G242C/MPISED1335/LPT http://forum.lcdinfo.com/viewtopic.php?f=6&t=906 |
| Author: | Beat_Slayer [ Mon Nov 08, 2004 22:07 ] |
| Post subject: | Seiko G242C/MPISED1335/LPT |
I've been reading this forum from some time ago and now comes a question: I've got a Seiko G242C with this pinout
I also bought a controller from MPI with SED1355 with this pinout in the connector to LCD
and this in the connector to LPT
So I don't have any experience in LCD and i wanted to know how to wire them! Thanks in advance! |
| Author: | Beat_Slayer [ Thu Nov 11, 2004 0:01 ] |
I've been reading info about LCDs, and now comparing the first two tables i get into a more direct question about the wiring! So I've done this table
and the question is: Knowing that my LCD is a single power supply (+5v) that has a built-in DC/DC converter, and the contrast adjustment its the VO, where should i connect those pins marked with "?"? I hope someone could give me some help on this problem while I'll try to uncover the connection to LPT! Thanks |
| Author: | coorz [ Thu Nov 11, 2004 2:27 ] |
Looks good. No need to connect the WF(M) pin. From SED>LCD do connect the corresponding Vo / VLC pins. From SED>LPT use a pot between Vo / VLC / GROUND as shown in the wiring schemes. |
