| EA W160-7KHLW 160x128 T6963 questions http://forum.lcdinfo.com/viewtopic.php?f=6&t=91 |
| Author: | wowbagger [ Wed Jan 15, 2003 15:22 ] |
| Post subject: | EA W160-7KHLW 160x128 T6963 questions |
hi """sorry for my bad english!!! i'm looking for a schematic for http://www.lcd-module.de/deu/pdf/grafik/w160-7.pdf to connect it to the LPT port an use LCDinfo. thanks in advance! wowbagger |
| Author: | Henri [ Thu Jan 16, 2003 11:43 ] |
Schematic for that display will be here when I have some time to draw it. |
| Author: | Henri [ Sat Jan 18, 2003 22:30 ] |
Sorry, I draw this already thursday evening but forgot to post here.
I'm not sure how you can change the font select and column select but as they are shown in the last page of the datasheet this should be possible. At least they are not in the 20 pin header. As I haven't tested this personally I can't promise it will work or doesn't cause any other harm but I think it should work. |
| Author: | wowbagger [ Sun Jan 19, 2003 1:27 ] |
hi thank you for the schematik, but i've founded out, that this lcd coasts about 200€... thats me to expensive... sorry for the work that i've made you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
| Author: | wowbagger [ Sun Jan 19, 2003 15:31 ] |
can i use this schematik with all t6963 160x128 lcds? |
| Author: | Henri [ Sun Jan 19, 2003 17:51 ] |
wowbagger wrote: can i use this schematik with all t6963 160x128 lcds?
No you can't. This display is different than most other I've seen. This doesn't have the FS and MD pins in the header and I don't remember seen the HALT signal in any other T6963C lcd. But the basic principle is the same with all T6963C displays no matter what size they are. |
| Author: | wowbagger [ Sun Jan 19, 2003 22:43 ] |
ok but if i know which connector on the lcdpcb have whitch signal, i can use this schematik? because i've buyed an lcd at ebay... |
| Author: | Henri [ Sun Jan 19, 2003 22:58 ] |
You can use it, but you may not find the HALT pin in the new display and the new display may have FS and MD pins + some other differences. If you know the pinout or where to get datasheet you could post it here and I could check what the difference is. |
