| LCD DEMO 64128A from Displaytech http://forum.lcdinfo.com/viewtopic.php?f=8&t=134 |
| Author: | whippersnapper [ Mon Feb 10, 2003 12:18 ] |
| Post subject: | LCD DEMO 64128A from Displaytech |
Hi everyone, I am looking for a demo to run my 64128A from Displaytech with. Is there any way to just hook up the LCD to my computer (I already saw a schematic for that connection) and run a demo program? Any answer in this regard is helpful and very appreciated. regards whip |
| Author: | Henri [ Mon Feb 10, 2003 16:56 ] |
What kind demo program you are looking for ? With this shematic you can use LCDInfo and the test programs I've made. You can also use the animation progs from MarkusM. http://www.skippari.net/lcd/ks0108.html You should only need to wire your display following the schematic and then install DLPortIO drivers if you don't have them and run the programs. |
| Author: | nrs8010246 [ Fri Sep 19, 2008 14:15 ] |
| Post subject: | Auto increment of column number |
Hello, In the displaytech 64128a, i understand that the coulmn number increments automatically after each read/write. I have a doubt: Assuming CS1 is selected and the address is column 63 and page zero. Now after the next read/write, what is the count of the column( 64 or zero ?). likewise, what is the page count (does it again start scanning from the same page 0 or does it go to page 1?) |
