| Toshiba T6963C controller with DMF-50773NY-LY (big girl) http://forum.lcdinfo.com/viewtopic.php?f=8&t=186 |
| Author: | LCD_gimp2 [ Wed Mar 26, 2003 6:11 ] |
| Post subject: | Toshiba T6963C controller with DMF-50773NY-LY (big girl) |
I have seen how helpfull henri has been, and was impressed and hopefull that I could receive some help here. I have got to interface this LCD to a Atmel Mega 128 processor. At the present stage, after following all the information provided to me through data sheets etc, i cannot get it to display a single thing... The language i am using is C. This is my code so far, just for initialisation....and i get nothing....? Code: //ICC-AVR application builder : 3/20/2003 5:32:05 PM
// Target : M128 // Crystal: 8.0000Mhz #include <iom128v.h> #include <macros.h> //# define for LCD controls #define CELO PORTA &= 0xBF //set chip enable on #define CEHI PORTA |= ~0xBF //set chip enable off #define WRLO PORTG &= 0x1B //set write signal enable #define WRHI PORTG |= ~0x1B //set write signal off #define RDLO PORTA &= 0x7F //set read sig enable #define RDHI PORTA |= ~0x7F //set read sig off #define CDLO PORTA &= 0xDF //set CD sig low #define CDHI PORTA |= ~0xDF //set CD high #define Reset_on PORTA &= 0xEF //reset LCD #define Reset_off PORTA |= ~0xEF //stop reset #define reset PORTF = 0x00 //turn off LED's //#define for LED indicators on and off #define LED_STS1 PORTF |= 0x04 //turn status LED on #define LED_STS0 PORTF &= ~0x04 //turn status LED off void port_init(void) { PORTA = 0xF0; DDRA = 0xFF; PORTB = 0x00; DDRB = 0x00; PORTC = 0x00; //m103 output only DDRC = 0xFF; PORTD = 0x00; DDRD = 0x00; PORTE = 0x00; DDRE = 0x06; PORTF = 0x00; DDRF = 0xFF; PORTG = 0x04; DDRG = 0x04; } void Delay_L(void) //this is a visible delay (long) { int x ; //define variables used unsigned char y, z; for (x = 1; x<25; x++) { //PORTF = 0x04 ; //turn on LED to indicate at this position for (y = 1; y; y++) { for (z = 1; z; z++) { _NOP() ; //perform no operation _NOP() ; _NOP() ; } //PORTF = 0x00 ; //turn off indicator LED } } } void Delay(void) //short delay - cannot be detected by human eye { unsigned char a, b; for (a=1; a; a++) for (b=1; b; b++) ; } //call this routine to initialise all peripherals void init_devices(void) /*This routine is inserted by the built in wizard*/ { //stop errant interrupts until set up CLI(); //disable all interrupts XDIV = 0x00; //xtal divider XMCRA = 0x00; //external memory port_init(); MCUCR = 0x00; EICRA = 0x00; //extended ext ints EICRB = 0x00; //extended ext ints EIMSK = 0x00; TIMSK = 0x00; //timer interrupt sources ETIMSK = 0x00; //extended timer interrupt sources SEI(); //re-enable interrupts //all peripherals are now initialised } void CE_strobe(void) //takes chip enable low and then high { //after a short delay CELO ; _NOP() ; _NOP() ; CEHI ; return ; } unsigned char Status_return(void) //enables specfic status check { //returns full status for user to check in main code unsigned char status1 ; //variable for storing status DDRC = 0x00 ; //sets up port c for input CDHI ; //sets up ports correctly for reading in from LCD RDLO ; WRHI ; CELO ; Delay() ; status1 = PINC ; //reads the values on all pins of port C CEHI ; DDRC = 0xFF ; return (status1) ; //returns the status to the main } void Status_chk(void) //a generic status check with pins 1 & 2 not busy { //returns to position when called & executed unsigned char status2, w ; //continues to check until status ok DDRC = 0x00 ; //sets up port c for input CDHI ; //sets up ports correctly for reading in from LCD RDLO ; WRHI ; do { CELO ; //set CE low _NOP() ; _NOP() ; status2 = PINC ; //read status of port C CEHI ; //sets ce high again w = status2 & 0x03 ; // does logical and with 0000 0011 } while (w != 0x03) ; //this checks if status of bits 0 & 1 is ok to go DDRC = 0xFF ; //set portC back to output port //port_init() ; //reset ports to orig and these must be //set by each operation after status check //LED_STS1 ; //turns on LED's to indicate that status is ok. return ; } void data_w(void) { CDLO ; //setting ports for a data write WRLO ; //CD taken low, WE low, RD hi RDHI ; Status_chk() ; //check LCD status for write CE_strobe() ; //strobe chip enable to write data return ; } void data_r(void) { CDLO ; RDLO ; WRHI ; return ; } void command_w(void) { CDHI ; WRLO ; RDHI ; Status_chk() ; CE_strobe() ; return ; } void LCD_init(void) { //mode PORTC = 0x80 ; //put 0x80 to port C to set mode of LCD //"or" mode with built in ROM enabled command_w() ; //write command to LCD controller //control word - graphic home add PORTC = 0x00 ; //put 00 on port C twice to set graphic home add data_w() ; //and write it to the LCD PORTC = 0x00 ; data_w() ; PORTC = 0x42 ; //put 0x42 on port C - signifies Graphic home add command_w() ; //write to LCD //graphic area PORTC = 0x1E ; //set graphics area - 1E is 30 columns data_w() ; PORTC = 0x00 ; data_w() ; PORTC = 0x43 ; //graphic area command tag command_w() ; //text home address PORTC = 0x00 ; //send 00 to port C to set text home add lower data_w() ; PORTC = 0x10 ; //send 10 to port C to set text home add upper data_w() ; PORTC = 0x40 ; //text home add set command command_w() ; //text area set PORTC = 0x1E ; //no. of text area = 30 colums data_w() ; PORTC = 0x00 ; data_w() ; PORTC = 0x41 ; //text area set cmd command_w() ; } void main(void) { unsigned char st = 0x00, gp = 0x00 ; //stat, b ; init_devices(); Reset_on ; //Hardware LCD reset Delay_L() ; //Delay >=1ms Reset_off ; //Set reset back to high //Status_chk() ; LCD_init() ; PORTF = 0x04 ; //turns on status LED to indicate initialisation //complete Delay_L() ; //port_init() ; //PORTF = 0x02 ; /* do { st = Status_return() ; gp = st & 0x03 ; } while (gp != 0x03) ; PORTF = st ; */ PORTC = 0x90 ; //ensure cursor is off command_w() ; //Delay_L() ; //Status_chk() ; do { st = Status_return() ; gp = st & 0x03 ; } while (gp != 0x03) ; PORTF = st ; PORTC = 0x93 ; //turn cursor on and blink command_w() ; Delay_L() ; //reset ; PORTC = 0x01 ; //to set cursor position data_w() ; PORTC = 0x01 ; data_w() ; PORTC = 0x21 ; command_w() ; PORTC = 0x00 ; //8 line width cursor data_w() ; PORTC = 0x00 ; data_w() ; PORTC = 0xA7 ; command_w() ; do { st = Status_return() ; gp = st & 0x03 ; } while (gp != 0x03) ; PORTF = st ; } These final status checks are to get the status back and display it on some led's i have hooked up - that is all. If someone could help i would be eternally gratefull.... NOTE: if anyone wants a picture of the layout i can provide that - just ask |
| Author: | Henri [ Wed Mar 26, 2003 13:42 ] |
I'll lock this topic as it's posted also here: http://www.skippari.net/phpBB2/viewtopic.php?t=188 |
