It is currently Sat Oct 17, 2026 4:57
PostPosted: Tue Dec 14, 2004 15:44
Hi everybody, I hooked up my nokia 3310 screen to my parallel port, and it works, however after about 30 seconds, the lcd gets blank. I downloaded a parallel port monitor and discovered that after about 30 sec. D0-D7 get low, and then turn high again. Does anyone know what is causing my port to do this? I tried different parallel port settings but that doesn't help.
Gideon
PostPosted: Thu Dec 16, 2004 22:32
Do you have some printer drivers installed that are using the LPT port ? Just guessing here but sounds like something else could be accessing the port also.
Anyone else seen similar behaviour ?
PostPosted: Wed Dec 22, 2004 20:36
No, nothing, that is what I thought of first. I did have a parallel fingerprintscanner, but after I formatted, the problem remains ( and it is pissing me off big time because nobody knows what the problem is :( )
Gideon
PostPosted: Thu Dec 30, 2004 20:16
Here is mentioned something about XP doing writes to the port:
http://www.lvr.com/jansfaq.htm
Q: If a logic 1 is written to the Control Port, bit 0, (Strobe), the PC clears all of the port bits once every five seconds for about a minute.
A: Some versions of Windows XP look for devices by periodically writing to the port. A registry key can disable this behavior.
The following registry setting disables the port writes:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Parport\Parameters]
"DisableWarmPoll"=dword:00000001
The following registry setting enables the port writes:
"DisableWarmPoll"=dword:00000000
You can make these changes in Windows' regedit utility. Or to make the changes automatically, create and save the following text files:
DisableWarmBoot.reg contains the following text:
Windows Registry Editor Version 5.00
EnableWarmBoot.reg contains the following text:
To change a registry key, run the program.
As always, use caution when working with the registry, which contains critical values for configuring and running the PC.
After making a change, reboot the PC.
Disabling the port writes can also eliminate port timeout errors received in some applications.
Thanks to Richard Shotbolt for informing me of this fix.
I don't know if this has anything to do with it though.
