It is currently Thu Nov 12, 2026 13:08
 Post subject: wg12864b graphic lcd
PostPosted: Tue Aug 24, 2004 1:13
i'm new in working with lcd and i've been searching for complete infos on how this lcd wg12864b works,but i'm still confused .
how do i initialise this lcd ?
i tried writing a code but it didn't work
any knowledge would be helpful
thank you
 Post subject: ks0108
PostPosted: Tue Aug 24, 2004 1:53
this lcd has a ks0108 controller
please i need your help
PostPosted: Tue Aug 24, 2004 11:32
do you want to use LCDInfo to drive your LCD or do you want to make your own driver?
In case you want to use LCDInfo, then there is a ready to use driver. It works perfect, since I use a 128 x 64 dot LCD with the same controller.
In case you want to make your own driver then you can find a complete datasheet on the folloing link: http://www.eio.com/ks0108b.pdf
Regards
Tom
PostPosted: Tue Aug 24, 2004 13:09
i have no idea about lcdinfo
all i know is that this lcd has a built in controller ks0108
i wrote a piece of code but it didn't work i don't know why i'm using 16f877
here's the code:
list p=16f877
#include <p16f877.inc>
LCD_DATA EQU PORTC ; LCD data lines interface
LCD_DATA_TRIS EQU TRISC
LCD_CTRL EQU PORTA ; LCD control lines interface
LCD_TEMP EQU 0x020 ; LCD subroutines internal use
R1 EQU 0x21
R2 EQU 0x22
DELAY EQU 0x023 ; Used in DELAYxxx routines
X_DELAY EQU 0x024 ; Used in X_DELAYxxx routines
; PORTA control bits
LCD_E EQU 2 ; LCD Enable control line
LCD_RW EQU 1 ; LCD Read/Write control line
LCD_RS EQU 0 ; LCD Register-Select control line
CS1 EQU 3
CS2 EQU 4
Rst EQU 5
ORG 0X00
main BCF STATUS,RP1 ;turns to Bank 1
BSF STATUS,RP0
MOVLW 0x06 ; Configure all pins
MOVWF ADCON1 ; as digital inputs BSF STATUS,RP0
MOVLW B'00000111'
OPTION
CLRF TRISA
MOVLW H'00'
MOVWF TRISC
BCF STATUS,RP0
CLRF PORTA
CLRF PORTC
BSF LCD_CTRL, LCD_RS ; Set LCD in command
BSF PORTA,5
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BCF PORTA,5
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
BSF PORTA,5
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
MOVLW 40H ;Set Y Column Address >From 0
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOVLW H'B8' ;Set Page From 0
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOVLW H'C0' ;Set Display Start Line
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOVLW H'3F' ;Set Display ON
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
SHOWC: CLRF R1
CLRF R2
SCLOOP1:
MOVLW H'B8' ;Set Page Address FROM 00H
ADDWF R1,W ;Command B8H~BFH
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
MOVLW 0x40 ;Set Column Address FROM 40H
CALL WRITE_COMMAND1
CALL WRITE_COMMAND2
SCLOOP2 CALL table
CALL WRITE_DATA1
INCF R2,1
MOVLW D'15'
SUBWF R2,W
BTFSC STATUS,Z
GOTO main
GOTO SCLOOP2
table MOVF R2,W
ADDWF PCL,1
RETLW H'8C'
RETLW H'92'
RETLW H'92'
RETLW H'62'
RETLW H'80'
RETLW H'FE'
RETLW H'92'
RETLW H'92'
RETLW H'92'
RETLW H'80'
RETLW H'8C'
RETLW H'92'
RETLW H'92'
RETLW H'62'
RETLW H'00'
WRITE_COMMAND1 MOVWF LCD_TEMP ; Command to send is in W ;Write Command To CS1
BCF LCD_CTRL,CS1
BSF LCD_CTRL,CS2
BCF LCD_CTRL, LCD_RW ; Set LCD in read mode
BCF LCD_CTRL, LCD_RS ; Set LCD in command mode
MOVF LCD_TEMP, W
MOVWF LCD_DATA
BSF LCD_CTRL, LCD_E ; LCD E-line High
NOP
NOP
NOP
NOP
BCF LCD_CTRL, LCD_E ; LCD E-line Low
RETURN
WRITE_DATA1 ;Write Data To CS1
BCF LCD_CTRL,CS1
BSF LCD_CTRL,CS2
BSF LCD_CTRL, LCD_RS ; Set LCD in command mode
MOVF LCD_TEMP, W
MOVWF LCD_DATA
NOP
RETURN
WRITE_COMMAND2 ;Write Command To CS2
BSF LCD_CTRL,CS1
BCF LCD_CTRL,CS2
MOVF LCD_TEMP, W
MOVWF LCD_DATA
NOP
RETURN
;LCDINIT
; Busy-flag is not yet valid
; CLRF LCD_CTRL ; ALL PORT output should output Low.
; power-up delay
; MOVLW 0x050
; CALL X_DELAY500
; MOVLW 0x030 ; 8-bit-interface, 2-lines
; CALL LCDPUTCMD
;MOVLW 0x009
; CALL X_DELAY500
; CALL LCDPUTCMD
;CALL X_DELAY500
; CALL LCDPUTCMD
;MOVLW 0x030 ; 8-bit-interface, 2-lines
; CALL LCDPUTCMD
;MOVLW 0x008 ; 8-bit-interface, 2-lines
; CALL LCDPUTCMD
;MOVLW 0x001 ; 8-bit-interface, 2-lines
; CALL LCDPUTCMD
;MOVLW 0x007 ; 8-bit-interface, 2-lines
; CALL LCDPUTCMD
END
PostPosted: Mon Aug 30, 2004 15:34
I suppose you might have better chance to get meaninful answers if you post to the correct forum as this forum is for the program called LCDInfo.
I'll move your topics to the development forum section.
