It is currently Thu Nov 12, 2026 13:10
PostPosted: Mon Sep 06, 2004 8:55
I have read the datasheets several times, but as of yet am unable to display a single dot! I believe my problem is in timing. Although the
datesheets show the timimg associated with interface selection (80 or 68).
If someone knows how to toggle the different pins and any associated delay required would be deeply appreciated. I'm new microcontrollers, so if you have code, I would understand it better if it is in assembly insteated of C++ or others.
PostPosted: Mon Sep 06, 2004 9:33
hi,
I can give you the sources of the sed1520 driver for LCDInfo. It's in C++.
It's working fine with me lcd but i can't say if it will work with yours. (Meanwhile i've seen so much different sed1520 displays 8O)
Have a look in this thread, where you can find the manual and the wiring for me lcd.
http://www.skippari.net/phpBB2/viewtopic.php?t=637
