It is currently Wed Oct 28, 2026 5:04
Post new topic Reply to topic  [ 288 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 20  Next
 Post subject: Hi tr0picana
PostPosted: Sat Jun 09, 2007 2:20
What circuit did you follow? Are you referring to something on the Sparkfun web page?
If you didn't use the 4MHz quartz crystal with the AVR microcontroller, there might be some problems with the clock set-up code in the example you used. I'm not familiar with the AVR product line, but the one's I am familiar with (PIC, MSP, ARM), part of the initialization code selects the clock source for the microcontroller CPU and peripherals. If you didn't have the crystal but the code expected it, there would be a problem...
Jon.
PostPosted: Sun Jun 10, 2007 4:15
I'm using the circuit diagram at http://www.geekland.org/e-dsp.com/wp-content/uploads/2006/02/lcd2_schematic.gif
And yes I used the 4mhz quartz crystal.
It turns out that the LCDs I ordered from Ebay have the Phlips chipset and so the code I used didn't work. Now I got it to work with an LCD I ordered from Sparkfun.
PostPosted: Sat Jul 28, 2007 18:08
Can you give me the source code to use LCD(Nokia6610'Epson) with ARM7 2119.Please,Thank you
PostPosted: Sat Jul 28, 2007 18:09
Can you give me the source code to use LCD (Nokia6610 ' Epson) with ARM7 2119. Please , Thank you
PostPosted: Sat Jul 28, 2007 18:11
PostPosted: Thu Aug 02, 2007 13:49
Hello can someone can give CCS code for LCD(NOKIA) for 18F4550.
the problem is that in the connexion given in HOBBYPIC some pins donsnt existe in the PIC18F4550 like RC5..
PostPosted: Sun Aug 05, 2007 14:39
Hi every body,
I have bought a graphical LCD from a Nokia mobile phones part provider store.
it has 10 goldplated contacts , green PCB and the following numbers has been printed on the back of it :
2L0571
10084P01 0252EE10084P01 0252EE
48502034850203
3388370005
http://translate.google.com/translate?hl=en&sl=ru&u=http://www.mobile-files.ru/forum/archive/index.php/t-75356.html&sa=X&oi=translate&resnum=1&ct=result&prev=/search%3Fq%3D10084p01%2Bnokia%2Blcd%26hl%3Den%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-US:official%26hs%3Dahe
but I don't know its PIN configuration and how to drive it with an atmel AVR MCU...
your attention would be helpful
thanks[/list][/url]
PostPosted: Sun Aug 05, 2007 14:41
Hi every body,
2L0571
48502034850203
3388370005
thanks[/list][/url]
PostPosted: Sun Aug 05, 2007 14:42
Hi every body,
2L0571
48502034850203
3388370005
thanks
PostPosted: Sun Aug 05, 2007 14:43
Hi every body,
it has 10 goldplated contacts, green PCB and the following numbers has been printed on the back of it :
2L0571
48502034850203
3388370005
thanks
PostPosted: Sun Aug 05, 2007 14:44
Hi every body,
2L0571
10084P01 0252EE
4850203
3388370005
thanks
PostPosted: Sun Aug 05, 2007 14:45
Hi every body,
2L0571
10084P01 0252EE
4850203
3388370005
thanks
 Post subject: how to use graphical LCD
PostPosted: Sun Aug 05, 2007 14:47
Hi every body,
2L0571
10084P01 0252EE
4850203
3388370005
thanks
PostPosted: Sat Oct 13, 2007 8:46
I am writing a BMP converter and will post but am not sure about the format for a C .h file. Would the following be OK?
const unsigned char bmp [] = {
0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xDA, 0x96, 0x52, 0x4E, 0x2E, 0x2E, 0x2E, 0x4E, 0x72, 0xB6, 0xDA, 0xFE,
0xFE, 0xFA, 0xFE, 0xFE, 0xFA, 0xFA, 0xFE, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFA, 0xFA,
0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24, 0x24,
0x24, 0x24, 0x44, 0x44,
