It is currently Sun Nov 15, 2026 23:05
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Aug 24, 2005 16:58
After some research and some help from u guys I have a "plot-pixel"-function ready 2 use. It is not well coded but it works :wink:
Here it is:
void Plot(int X, int Y, int mode)
   unsigned char pixelvalue = 0x10;
   if ((X>-1) && (X<128) && (Y>-1) && (Y<64))
      if (mode==0) arrayLCD[(X>>3)+(Y<<7)] = arrayLCD[(X>>3)+(Y<<7)] & (255-(1<<(7-(X&7))));
      if (mode==1) arrayLCD[(X>>3)+(Y<<7)] = arrayLCD[(X>>3)+(Y<<7)] | 1<<(7-(X&7));
      if (mode==2) arrayLCD[(X>>3)+(Y<<7)] = arrayLCD[(X>>3)+(Y<<7)] ^ 1<<(7-(X&7));
      SetColumn(X);
      switch(Y%8)
         case 0:   pixelvalue = 0x01; break;
         case 1:   pixelvalue = 0x02; break;
         case 2:   pixelvalue = 0x04; break;
         case 3:   pixelvalue = 0x08; break;
         case 4:   pixelvalue = 0x10; break;
         case 5:   pixelvalue = 0x20; break;
         case 6:   pixelvalue = 0x40; break;
         case 7:   pixelvalue = 0x80; break;
         default: pixelvalue = 0x10;
      if(Y<8)
      {   SetPage(0);}
      else if(Y>=8 && Y<16)
      {    SetPage(1);}
      else if(Y>=16 && Y<24)
      {    SetPage(2);}
      else if(Y>=24 && Y<32)
      {    SetPage(3);}
      else if(Y>=32 && Y<40)
      {   SetPage(4);}
      else if(Y>=40 && Y<48)
      {    SetPage(5);}
      else if(Y>=48 && Y<56)
      {    SetPage(6);}
      else
      {    SetPage(7);}
      SendLCDData(&pixelvalue,1);
Still I don't know if I need the array, but I think it's nice 2 have if u want 2 check if the pixel is on or off. Must say THX 2 Micheal 4 the excellent idea about "Y%8"
Note: This function is for KS0108, not tested with other controllers.
Have fun
Kneego
PostPosted: Wed Aug 24, 2005 19:45
Might also do the trick...
      if (mode==0) arrayLCD[X+((Y>>3)<<7)] = arrayLCD[X+((Y>>3)<<7)] & (255-(1<<(Y&7)));
      if (mode==1) arrayLCD[X+((Y>>3)<<7)] = arrayLCD[X+((Y>>3)<<7)] | 1<<(Y&7);
      if (mode==2) arrayLCD[X+((Y>>3)<<7)] = arrayLCD[X+((Y>>3)<<7)] ^ 1<<(Y&7);
      SetColumn(X);
      SetPage(Y>>3)
      SendLCDData(arrayLCD[X+((Y>>3)<<7)],1);
PostPosted: Thu Aug 25, 2005 9:37
Excellent Zee!!! :)
Your code works. Much better than mine and with only one single line instead of several if and switch statements.
It's hard for me to think the numbers or codes bitwise but u done that easily.
THX Zee.
Kneego
PostPosted: Fri Aug 26, 2005 23:41
Kneego, thankx for you help
I've [almost] completed adding unicode support along with BIG5 and GB2312 support. Thats over 20000 CJK characters, from native point9 to point 24.
PostPosted: Sat Aug 27, 2005 11:05
Glad 2 be some help. U help me I help u that's the idea. Very impressed, 20 000 characters, wow. Must be alot of work...
Keep on going...
Kneego
