It is currently Thu Oct 29, 2026 6:43
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
PostPosted: Fri Feb 21, 2003 23:01
I can monday post that function.. My own computer is OULU city and i don't.. Sorry.. I hope at you understand..
Rengas joka ei vedä, se jarruttaa - Nissan Sunny 1.6 SLX 4x4
PostPosted: Fri Feb 21, 2003 23:07
delete
I send to you and to Emil a 'mail with the module for Visual Basic.
Anyone can post the function to draw bytes ¿?!
PostPosted: Fri Feb 21, 2003 23:10
delete
PostPosted: Fri Feb 21, 2003 23:24
Most like:
'normal address system.. high/lowbyte, x, y, i don't remember
Write_Command(&H24)
Write_Data(data)
Write_Command(&HC0)
I post monday tested source..
Sorry bad english..
PostPosted: Sat Feb 22, 2003 0:11
I have a function that write text to the LCD and another that write pixels giving a position (x,y). Now I need to know hoy you make to draw a whole bitmap with bytes (one byte per pixel).
Anyone could help me again ?? :roll: :roll: :roll:
Thanks.
PS: Emil look in the code that i have passed to you, that the wiring is the same of that you have.
PostPosted: Sat Feb 22, 2003 0:23
delete
PostPosted: Sat Feb 22, 2003 1:18
We can't communicate :D :D :D :D
I need a function that draw to the LCD the bytes. The function you post here, only converts pixels into hexadecimal values. I need the function that draw this pixels (in hexadecimal).
PostPosted: Sat Feb 22, 2003 1:20
delete
PostPosted: Sat Feb 22, 2003 1:25
delete
PostPosted: Sat Feb 22, 2003 1:29
Great code but,
You don't understand me.
I need a function that DRAW !! PAINT !! to LCD.
Do you speak or understand Spanish ¿?
NEcesito una función que dibuje los bytes en el LCD !
PostPosted: Sat Feb 22, 2003 11:31
Ok, here's one piece of code that writes a bitmap to T6963C. I have translated this from some delphi code last spring so this isn't my work.
void cT6963C::ShowBMP(Graphics::TBitmap *pBitmap)
  int x=0,y=0,z;
  int i;
  int addr;
  float pp;
  TColor p;
  Randomize();
  addr = G_BASE + (y*BYTES_PER_ROW_GFX) + (x/font_width);
  T6963C.WriteData(addr & 0xFF);
  T6963C.WriteData(addr >> 8);
  T6963C.WriteCtrl(0x24);
  for (y=0;y<ypixels;y++)
    for (x=0;x<xpixels/font_width;x++)
      i=0;
      for(z=0;z<font_width;z++)
        p=pBitmap->Canvas->Pixels[x*font_width+z][y];
        pp=0.6*(p & 0xFF)+0.30*((p >> 8) & 0xFF)+0.1*((p >> 16) & 0xFF);
        i=i << 1;
        if (pp<=random(255))
           i=i | 1;
      T6963C.WriteData(i);
      T6963C.WriteCtrl(0xC0);
PostPosted: Sat Feb 22, 2003 14:27
The ypixels and xpixels variables what value have ¿?
240 and 128 respectively ¿?
PostPosted: Sat Feb 22, 2003 16:41
Yes, 240 and 128 for your display.
PostPosted: Sat Feb 22, 2003 19:16
delete
