It is currently Thu Oct 29, 2026 7:33
Post new topic Reply to topic  [ 163 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10, 11  Next
PostPosted: Wed Mar 05, 2003 19:26
I have the same problem all the time :evil: :evil: :evil: :evil: , perhaps my function to convert bitmaps to hexadecimal values doesn't work properly. The function convert in format 8x8 and 6x8. Probably, the 6X8 format, doesn't work well :cry: :cry: :cry: .
I will agree if anyone can post the code of his function to convert BMP's, to the 6X8 hexadecimal values. For try if that be the problem :? .
Thanks.
PostPosted: Thu Mar 06, 2003 1:35
Del
PostPosted: Thu Mar 06, 2003 1:36
General Error
PostPosted: Thu Mar 06, 2003 1:37
General Error
PostPosted: Thu Mar 06, 2003 22:49
Hi!
It's only a question, can be used this function to display 6X8 and 8X8 hexadecimal values ???
Public Sub sbrDrawLCDHex(ByVal pvstrPoints() As String)
        Dim shtAdreça As Short
        Dim shtcont As Short
        shtAdreça = G_BASE '+ (0 * BYTES_PER_ROW) + (0 / 6)
        WriteData(shtAdreça And &HFF)
        WriteData(RShiftLong(shtAdreça, 8))
        WriteCtrl(&H24)
        For shtcont = 1 To UBound(pvstrPoints)
            WriteData(CInt("&H" & pvstrPoints(shtcont)))
            'WriteData(CInt(pvstrPoints(shtcont)))
            WriteCtrl(&HC0)
        Next
    End Sub
I think that only work with 8X8 hexadecimal values, and for this reason my display goes crazy when draw a BMP of 6X8. Anyone can modify or tell me, what Can i do to display 6X8 ???
It's for a T6963C and 240x128.
Thank you
 Post subject: SED1330
PostPosted: Tue Mar 11, 2003 2:15
Hi Peopel
It's work SED1330 Screen 320x240
Picture from PowerLCD 2.0
With Visualize :wink:
Greetings Emil
PostPosted: Tue Mar 11, 2003 19:13
Good Emil !
But I'm still having the same problem,the function that i posted few days ago only works me with 8X8 hexadecimal values.
When I try to display a 6X8, the LCD seems to be crazy :lol: :lol: :lol:
I hope someone could help me, I'm frustate ! 8O 8O 8O 8O
Thanks and regards.
PostPosted: Tue Mar 11, 2003 21:20
Hi Marc
i will help you
Sorry i can in the moment not check your problem
i have not a controller with T6963
I will check it when i have a T6963 then i will help you..
Greetings Emil
PostPosted: Tue Mar 11, 2003 21:23
Any Day a new Dialog
Picture von PowerLCD 2.0 convert to my Prog
System Info finish
Greetings Emil
PostPosted: Wed Mar 12, 2003 19:30
and a new
MBM Info and Weather finish
Greetings Emil
 Post subject: T6963C external memory
PostPosted: Mon Mar 31, 2003 16:50
I am now working on the interface of the T6963C and the LCD (HITACHI) SP10Q003-T. May i know which external memory to use? I found that TC5565 is used widely. However, I cant seem to find the specifications for it. Can anyone help? Thanks.
 Post subject: Sorry
PostPosted: Mon Mar 31, 2003 17:01
I forgot to give the specs for LCD. Its a 240x320 LCD. My microcontroller would be a motorola HCS12 chip. Is it possible for me to build a LCD interface that can be connected to any microcontroller? Where to programme the code to control the display on LCD? Is it the T6963C or the HCS12?
HELP!!! :(
 Post subject: Re: Sorry
PostPosted: Wed Apr 02, 2003 0:01
Charles wrote:
HELP!!! :(
What are you exactly trying to do ? Do you have a 320x240 display without a controller and want to use external controller with that ?
I don't remember seeing T6963C used with this big displays and can't remember the specs right now but SED133x controllers are at least used with this display size.
You can't program T6963C or SED133x itself so the code goes to the microcontroller.
 Post subject: HITACHI SP10Q003-T
PostPosted: Fri Apr 04, 2003 6:03
Thanks for your reply. I am trying to use an external controller which is the T6963 to control the LCD. I have problem trying to connect the two components together (in the hardware sense).
Thank you.... :)
PostPosted: Sat Apr 05, 2003 21:29
I have never used external controllers but there has been discussion about this at LiQuiD-MP3 forum:
http://forum.schijf.org
