| LCD graphics Color optrex 51373 320x240 http://forum.lcdinfo.com/viewtopic.php?f=9&t=1041 |
| Author: | adiaz [ Tue Feb 08, 2005 21:17 ] |
| Post subject: | LCD graphics Color optrex 51373 320x240 |
hello.before all srry for my english. I have a new lcd 320x240 pixels. techdisplay 51373 of the company OPTREX. I need good software for it. Can someone tell me some C prog ? The lcd is not have diriver controller. I attach the leaf(sheet) of information to this message, and am trying to do the intefaz with a microcontroller of 8 bits of the company atmel. This microcontroller this one connected directly to his(her,your) income of information and of control, nevertheless I have not been lucky on having tried to open information of correct form. Great Agradecere if it(he,she) had some information in the matter and could share it. I use language C or in assembler. thank's |
| Author: | Henri [ Sat Feb 12, 2005 12:22 ] |
You need to be more specific with your request. What hardware are you interfacing the display with, what controller do you have for the display ? |
| Author: | adiaz [ Sat Mar 19, 2005 16:30 ] |
mas facil de lo que parecia, usese como una matix de leds |
| Author: | coorz [ Sat Mar 19, 2005 16:41 ] |
adiaz wrote: mas facil de lo que parecia, usese como una matix de leds
I doubt Henri understands that |
| Author: | Henri [ Wed Mar 23, 2005 21:27 ] |
I see you edited your post after my last message in this topic so I have missed that. As you say now that you have no controller for the color lcd I think you will have some trouble. These are used with controllers usually and I don't think you will find software to drive it without one. So you need to make your own and try if that's even possible without controller. |
| Author: | feramuz [ Fri Mar 09, 2007 18:04 ] |
| Post subject: | about optrex F-51900 5.7" color graphic LCD driver |
Henri wrote: You need to be more specific with your request. What hardware are you interfacing the display with, what controller do you have for the display ?
Hi, I am trying to drive optrex f-51900 color graphic lcd with atmega16 uc parallel port. I do not know any info to drive it? IST3028 chip used in this LCD. thank you, feramuz |
| Author: | Henri [ Fri Apr 20, 2007 21:13 ] |
If you can't find any example code then just read the controller datasheet carefully. You might not understand everything immediately but just keep trying and you should manage to figure it out. After all that is the way others have to do it too. |
