| Need a tester for my program http://forum.lcdinfo.com/viewtopic.php?f=9&t=113 |
| Author: | MaikRutsche [ Wed Jan 29, 2003 4:46 ] |
| Post subject: | Need a tester for my program |
Hi, i have written a T6963C-displaydriver, that can be used with all possible displaysizes. U can find it here: http://rogue.wh20.tu-dresden.de/~maik/glcds/eigenes/mlcdp/TreiberTest.zip Unfortunately its in german, but if you wish I translate it. Look at the T6963C.ini and setup your displayconfig. At the moment there are only 3 configs in it, because i have only these 3 displays, but its very easy to add new displaysizes. Thanks. |
| Author: | Henri [ Wed Jan 29, 2003 11:44 ] |
Hehe, that config file looks very much like what's in the latest LCDInfo version (not released yet). I'll test that when I get home. |
| Author: | Henri [ Thu Jan 30, 2003 10:38 ] |
This is some copy/paste from another topic: http://www.skippari.net/phpBB2/viewtopic.php?t=112 Henri wrote: I don't have a T6963C display using the Pollin wiring (i guess that's what you're using) at hand right now so I only was able to use the virtual lcd in the driver test but I can test this later. MaikRutsche wrote: You have a different wirring? All paramters are seperate adjustable. If you give me a schematic of your wiring then a could make a new option in the driver. Henri wrote: Yes, I have a display with the powerlcd wiring to test wiring settings in the new LCDInfo version. In that you can define yourself how you have the pins connected. But I also have a 240x64 display with the pollin wiring so I should be able to test your drivers soon. /* pollin*/ int wr=1; int rd=17; int cd=16; int ce=14; /* powerlcd*/ int wr=16; int rd=14; int cd=17; int ce=1; MaikRutsche wrote: So here is the new Version:
Driver-Testprogram: http://www.wh19.tu-dresden.de/~maik/glc ... erTest.zip Look at the T6963C.ini and you will find 4 new options: Pin_WR=1 Pin_CE=14 Pin_CD=16 Pin_RD=17 |
| Author: | Henri [ Thu Jan 30, 2003 10:41 ] |
I tested the driver with a 240x128 display using the powerlcd wiring but wasn't able to get it working. I was using the 240x64 setting but this shouldn't matter, I guess. With 240x64 display and pollin wiring it worked fine. I'll do some more testing tonight. |
| Author: | MaikRutsche [ Thu Jan 30, 2003 15:25 ] |
I have found the problem. The powerlcd-wiring is a little tricky because it use an not very clever wiring. The normal wiring connects inverted display pins to inverted lpt pins, the powerlcd wiring connects the inverted pin (WR) to a non inverted lpt pin (16 = Init) and a non inverted lcd pin (CD) to an inverted lpt pin (17= Select In). |
| Author: | Henri [ Thu Jan 30, 2003 15:45 ] |
I'm sure you have already figured it out but if you wan't see how I did it here's some code: http://www.skippari.net/phpBB2/viewtopic.php?p=555#555 |
| Author: | MaikRutsche [ Thu Jan 30, 2003 16:15 ] |
I updated my programm: http://rogue.wh20.tu-dresden.de/~maik/g ... erTest.zip Code: Pin_WR=16
Pin_CE=1 Pin_CD=17 Pin_RD=14 Should work now. |
| Author: | Henri [ Thu Jan 30, 2003 21:05 ] |
Hmm, I tried to download it from that link but got the old version ? |
| Author: | MaikRutsche [ Fri Jan 31, 2003 2:55 ] |
It was the wrong link, now it should be the new version http://rogue.wh20.tu-dresden.de/~maik/g ... erTest.zip |
| Author: | Henri [ Fri Jan 31, 2003 9:26 ] |
Now I quickly tested it with the 240x64 settings with 240x128 display and didn't notice any problems. I'll do more testing and the 240x128 config later today. |
| Author: | MaikRutsche [ Fri Jan 31, 2003 17:13 ] |
Nice If you want to play a little bit more, here's my a testversion of my programm: http://rogue.wh20.tu-dresden.de/~maik/g ... .01.31.zip Could you post your config for the 240x128? |
| Author: | Henri [ Fri Jan 31, 2003 21:29 ] |
This is what I did for 240x128 display: Code: [Disp240x128]
TextRows=16 TextColumns=40 GraphRows=128 GraphColumns=40 BitsPerGraphColumn=6 TextHomeAddress=$0000 GraphHomeAddress=$0300 ;CGRamHomeAddress=$1000 CGRamHomeAddress=$0002 I didn't make any changes to the CGRAM settings so... I need to have a look at that later. |
