It is currently Tue Oct 06, 2026 14:23
PostPosted: Wed Jun 08, 2005 18:50
Hi I've been having trouble displaying graphic images on my 240x128 lcd. Now my lcd is setup as follows:
Texthome 0x0000
Graphichome 0x0300
Displaymode 0x80
Now I have been able to display text without issue so far, but whenever I use fastlcd and save the bitmap to image array with font pin 6x8, and then load the hex into the microcontroller I get nothing on the lcd.
Here is the routine used to send the bitmap data to the T6963C controller:
void lcd_graphic(char *gdata) // send gdata to lcd
char ginfo
lcd_clear_graph();
dput(0x00);
dput(0x03);
cput(0x24);
while (ginfo = *gdata)
dput(ginfo);
cput(0xc0);
*gdata++; //*gdata points to the 5120 byte array
main:
void main(void)
mcu_init(); /* Initialize MCU */
ENABLE_LEDS;
lcd_setup(); // make sure control lines are at correct levels
lcd_init(); // initialize LCD memory and display modes
lcd_graphic(image); //image is the array of bitmap
while(1){}
most of the code if anyone has notice is from the CSOURCE for Dos from the website, by John P. Beale.
Can anyone help?
Just noticed something, Do i have to set the address pointer back to the graphic home address, after I finish transferring all the data?
Users browsing this forum: No registered users and 368 guests
