| Programming a T6963C (Visual Basic) http://forum.lcdinfo.com/viewtopic.php?f=9&t=127 |
Page 1 of 11 |
| Author: | Marc [ Thu Feb 06, 2003 0:42 ] |
| Post subject: | Programming a T6963C (Visual Basic) |
Hi all! First of all, sorry for my poor english. I have read all the posts that you have posted in this forum and I tried to program a very simple application that initializes the LCD, and write pixels using the functions that you have posted. I found some problems in the sbrSetPixel, my LCD doesn't display all the pixels, specially the last X coordinates. I will agree any help that you can give me. Thanks everyone. PD: PowerLCD works fine with my LCD, i will know how this program draw pixels. |
| Author: | Marc [ Thu Feb 06, 2003 12:03 ] |
| Post subject: | Sorry |
Sorry, in the post I don't say which is my LCD. LCD 240x128, controlled by Toshiba T6963C. The pins are this: D0-D7: Pin 2 - Pin 9 CE: Pin 1 C/D: Pin 17 RD: Pin 14 WR: Pin 16 All this pins are the parallel port. Thanks. |
| Author: | Henri [ Thu Feb 06, 2003 14:53 ] |
Could you also tell the settings you are using in the initialization. Are you programming in C ? |
| Author: | Marc [ Thu Feb 06, 2003 17:03 ] |
| Post subject: | Initialization |
I'm programming in Visual Basic .NET but I understand C code, in the initialization, i use G_BASE = &H300 T_BASE =&H0 BYTES_X_ROW = 40 Are u asking this ¿? Thanks |
| Author: | Marc [ Fri Feb 07, 2003 0:32 ] |
| Post subject: | Bufff. |
I passed hours trying to implement the functions that you hace posted in the post of Visual Basic. But there are no way to make this functionality. I will agree anyone who can help me posting the basic code (Init, PutPixel, ClearText, ... ) in C or in VB for my LCD. I tryed all the functions that Henri have posted, but i have a lot of problems, i think in timing, i don't know sure A lot of thanks. |
| Author: | MaikRutsche [ Fri Feb 07, 2003 4:59 ] |
Are u german? It would be more easy for me to explain how to control the T6963. Do you have the datasheet of the T6963? You will find all information in there. |
| Author: | Henri [ Fri Feb 07, 2003 11:11 ] |
Ok, I can post some T6963C test program code later. |
| Author: | Marc [ Fri Feb 07, 2003 12:36 ] |
| Post subject: | Thanks |
Thanks all, i'm not German. I'm Catalan. I have the T6963C datasheet, but i don't know why i have all this problems. Thanks for helping me |
| Author: | Henri [ Fri Feb 07, 2003 18:45 ] |
This code worked fine for me with 240x128 display using the powerlcd wiring: Code: #define G_BASE 0x0300 // grafiikkamuistin base address
#define T_BASE 0x0000 // tekstimuistin base address #define BYTES_PER_ROW 40 // merkkiä rivillä #define BASE 0x378 // lpt portin osoite void WaitDisplayReady(void) // reads the display status byte and checks // that the display is ready before writing // doesn't have any check in case the status byte // can't be read so this situation may cause a lockup { int Tmp; Tmp = DlPortReadPortUshort(BASE + 0x402); Tmp = Tmp & 0x1F; Tmp = Tmp | 0x20; DlPortWritePortUshort(BASE + 0x402, Tmp); do{ DlPortWritePortUshort(BASE + 2, 0x20 + 4 + 2); //In, CD=1, CS=0, Wr=1 DlPortWritePortUshort(BASE + 2, 0x20 + 4 + 2 + 8); //In, CD=1, CS=0, Wr=1, Rd=0 Tmp = DlPortReadPortUshort(BASE); DlPortWritePortUshort(BASE + 2, 0x20 + 4 + 2); //In, CD=1, CS=0, Wr=1 }while ((Tmp & 3) != 3 ); DlPortWritePortUshort(BASE + 2, 0); } void WriteData(USHORT Data) { /* pollin WaitDisplayReady(); DlPortWritePortUshort(BASE + 2, 0); // 0111 C/D low DlPortWritePortUshort(BASE + 2, 2); // 0011 WR low DlPortWritePortUshort(BASE, Data); DlPortWritePortUshort(BASE + 2, 3); // 0010 CE low DlPortWritePortUshort(BASE + 2, 2); // 0011 CE high DlPortWritePortUshort(BASE + 2, 0); // 0111 WR high */ /* powerlcd */ DlPortWritePortUshort(BASE + 2, 0x0c); // 0111 C/D low DlPortWritePortUshort(BASE + 2, 0x08); // 0011 WR low DlPortWritePortUshort(BASE, Data); DlPortWritePortUshort(BASE + 2, 0x09); // 0010 CE low DlPortWritePortUshort(BASE + 2, 0x08); // 0011 CE high DlPortWritePortUshort(BASE + 2, 0x0c); // 0111 WR high } void WriteCtrl(USHORT Command) { /* WaitDisplayReady(); DlPortWritePortUshort(BASE, Command); DlPortWritePortUshort(BASE + 2, 4); // 1111 C/D high DlPortWritePortUshort(BASE + 2, 4+2); // 1011 WR low DlPortWritePortUshort(BASE + 2, 4+3); // 1010 CE low DlPortWritePortUshort(BASE + 2, 4+2); // 1011 CE high DlPortWritePortUshort(BASE + 2, 0); // 0111 C/D low */ /* powerlcd */ DlPortWritePortUshort(BASE + 2, 0x04); // 1111 C/D high DlPortWritePortUshort(BASE + 2, 0x00); // 1011 WR low DlPortWritePortUshort(BASE, Command); DlPortWritePortUshort(BASE + 2, 0x01); // 1010 CE low DlPortWritePortUshort(BASE + 2, 0x00); // 1011 CE high DlPortWritePortUshort(BASE + 2, 0x0c); // 0111 C/D low } void InitLCD(void) { // Display init WriteData(T_BASE & 0xFF); // Data1: LowAddress WriteData(T_BASE >> 8); // Data2: HighAddress WriteCtrl(0x40); // Command: 0x40 -> 01000000 WriteData(BYTES_PER_ROW); // Data1: Colums WriteData(0); // Data2: 0 WriteCtrl(0x41); // Command: 0x41 -> 01000001 WriteData(G_BASE & 0xFF); // Data1: LowAddress WriteData(G_BASE >> 8); // Data2: HighAddress WriteCtrl(0x42); // Command: 0x42 -> 01000010 WriteData(BYTES_PER_ROW); // Data1: Colums WriteData(0); // Data2: 0 WriteCtrl(0x43); // Command: 0x43 -> 01000011 // Internal CGROM Mode, OR Mode WriteCtrl(0x80); // OR Mode // 80->10000000 WriteCtrl(0xa7); // cursor is 8 lines high WriteData(0x00); WriteData(0x00); WriteCtrl(0x21); // put cursor at (x,y) // DisplayMode WriteCtrl(0x9D); } void SetLCDXY(int x, int y) { int addr; addr = T_BASE + (y * BYTES_PER_ROW) + x; WriteData(addr & 0xFF); WriteData(addr >> 8); WriteCtrl(0x24); } void SetLCDCursor(int x, int y) { WriteData(x); WriteData(y); WriteCtrl(0x21); } void ClearLCDText(void) { int i; WriteData(T_BASE & 0xFF); WriteData(T_BASE >> 8); WriteCtrl(0x24); // address pointer to T_BASE for (i=0;i<640;i++) { WriteData(0); WriteCtrl(0xc0); // write data and inc ptr } } void ClearLCDGraph(void) { int i; WriteData(G_BASE & 0xFF); WriteData(G_BASE >> 8); WriteCtrl(0x24); // address pointer to G_BASE for (i=0;i<5120;i++){ WriteData(0); WriteCtrl(0xc0); // write data and inc ptr } } void PrintLCDText(char *string) { unsigned int i; char c; for (i=0;i<strlen(string);i++){ c = string[i] - 0x20; // conversion from ASCII to LCD characters if (c<0) c=0; WriteData(c); WriteCtrl(0xc0); } } void SetLCDPixel(int x, int y) { int addr; addr = G_BASE + (y*BYTES_PER_ROW) + (x/6); WriteData(addr & 0xFF); WriteData(addr >> 8); WriteCtrl(0x24); WriteCtrl(0xf8 | (5-(x % 6))); } void ClearLCDPixel(int x, int y) { int addr; addr = G_BASE + (y*BYTES_PER_ROW) + (x/6); WriteData(addr & 0xFF); WriteData(addr >> 8); WriteCtrl(0x24); WriteCtrl(0xf0 | (5-(x % 6))); } void main(void) { InitLCD(); ClearLCDText(); ClearLCDGraph(); SetLCDXY(2,7); PrintLCDText("Text juttu lisaa"); for(int i=0;i<240;i++) for(int j=10;j<50;j++) SetLCDPixel(i,j); for(int k=110;k<150;k++) for(int l=20;l<30;l++) ClearLCDPixel(k,l); for(int m=10;m<20;m++) for(int n=20;n<30;n++) ClearLCDPixel(m,n); } |
| Author: | Marc [ Fri Feb 07, 2003 22:29 ] |
| Post subject: | Thanks for the code |
A lot of thanks Henri, I 'm going to try it now I will comment the results. Thanks again |
| Author: | Marc [ Fri Feb 07, 2003 23:07 ] |
| Post subject: | Well |
Thanks to your code I have discovered my problems. It seems that the iterative cycles (for statements) didn't work properly, but i have solutioned yet. PD: If you would I can paste the code that I translate for VB .NET. A lot of thanks, |
| Author: | Henri [ Sun Feb 09, 2003 11:26 ] |
I'd like to see you posting your VB .NET code here if possible. |
| Author: | Marc [ Mon Feb 10, 2003 22:23 ] |
| Post subject: | Ok !! |
Ok! I will put the code on Wednesday, cause i'm in exams. Bye ! |
| Author: | Henri [ Tue Feb 11, 2003 18:31 ] |
No need to hurry |
| Author: | Marc [ Wed Feb 19, 2003 20:35 ] |
| Post subject: | Today night |
Today night i will post the code translation into VB.NET I don't understand your language, so i don't know what you say ... sorry (ADMIN EDIT: Marc means these posts) Thanks, and wait until night, please. Sorry for the late... Bye ! |
| Page 1 of 11 | All times are UTC + 2 hours |
