It is currently Wed Nov 25, 2026 18:06
PostPosted: Fri Jul 29, 2005 0:02
I have a hantronix HDM128GS12-1 display. It is a 128x128 graphic LCD that has a T6963 controller. I've been trying for about a week to try to get it functioning.
http://www.hantronix.com/2_1.html
All that I get is a quick flash (that looks like there are some characters and vertical bars) then it goes black.
I'm using an AT89S52 microcontroller, and I'm pretty sure it's wired correctly(i've checked several times, i get the negative voltage for the display and all other pins seem to be fine.)
Here is my code, it's a little messy but it should work.
The important functions are LCD_Cwrite, LCD_Dwrite, and Check_Status which are toward the bottom
Also all the P2 clears, are to make sure the code isn't hanging somewhere.
This does not seem to be the case since in the end all P2 bits are where they should be.
; Micro controller speed - 24MHz or 41.666ns
; 500ns per cycle
; Display Size 128x128
; WR, RD Pulse Width: 80ns min
; Pin Controls
; /RD Low + C/D High = Status Read
; /WR Low + C/D High = Command Write
; /WR Low + C/D Low  = Data Write
; Status Explanation
; bit 0 - Command Execution Capability
; bit 1 - Data Read/Write Capability
; bit 2 - Auto Mode Data Read
; bit 3 - Auto Mode Data Write
; bit 4 - Not Used
; bit 5 - Controller Operation Capability
; bit 6 - Error Flag: Used in Screen Peek and Screen Copy
; bit 7 - Check Blink Condition
; For 0-5 1 is enabled, 0 is disabled
; For 6   1 is error, 0 is no error
; For 7   0 is display off, 1 is normal display
; CE tie low
; FS tie low
$MOD52
;---------------------------Pin DECLARATIONS--------------------------------
LRD   bit P1.2   ;
LWR   bit P1.3   ;
CD   bit P1.4   ;
RST   bit P1.5   ;Inverted : 0 for On, 1 to Reset LCD
CE   bit P1.6   ;
LCD_Voltage   bit   P3.1   ;Inverted  0 for -17v, 1 to 0v to LCD
Data_Bus   equ   P1
;---------------------------Constant DECLARATIONS---------------------------
Graphic_Low   equ   00
Graphic_High   equ   00
Graphic_Column   equ   10h
Text_Low   equ   00
Text_High   equ   08
Text_Column   equ   10h
ORG 0000H
LJMP LCD_Setup
ORG 100h
LCD_Setup:
   MOV   P1,#0
   MOV   P3,#0
   CLR   P2.0
   SETB   RST
   SETB   LCD_Voltage
   ;Wait 75ms
   MOV   B, #150
   LCALL   DELAY
   CLR   RST
   NOP
   NOP
   NOP
   NOP
   SETB   LWR
   SETB   LRD
   CLR   CE
   ;Wait 75ms
   MOV   B, #150
   LCALL   DELAY
;Text Home
   MOV   R4,#Text_Low
   LCALL   LCD_DWrite
   MOV   R4,Text_High
   LCALL   LCD_DWrite
   MOV   R4,#040h
   LCALL   LCD_CWrite
;Graphics Home
   MOV   R4,#Graphic_Low
   LCALL   LCD_DWrite
   MOV   R4,#Graphic_High
   LCALL   LCD_DWrite
   MOV   R4,#042h
   LCALL   LCD_CWrite
;Text Area
   MOV   R4,#Text_Column
   LCALL   LCD_DWrite
   MOV   R4,#0
   LCALL   LCD_DWrite
   MOV   R4,#041h
   LCALL   LCD_CWrite
;Graphics Area
   MOV   R4,#Graphic_Column
   LCALL   LCD_DWrite
   MOV   R4,#0
   LCALL   LCD_DWrite
   MOV   R4,#043h
   LCALL   LCD_CWrite
;Set Mode
   MOV   R4,#81h
   LCALL   LCD_CWrite   ;XOR, Internal CG
   CLR   P2.1
   LCALL   Clear_Graphics
   LCALL   Clear_Text
;Allow Vlcd
   CLR   LCD_Voltage
   CLR   P2.2
;DISPLAY MODE
   MOV   R4,#9Ch
   LCALL   LCD_CWrite
;Set Cursor Pattern
   MOV   R4,#0
   LCALL   LCD_DWrite
   MOV   R4,#0
   LCALL   LCD_DWrite
   MOV   R4,#0A2h
   LCALL   LCD_CWrite
;Set Cursor Location
   MOV   R4,#1
   LCALL   LCD_DWrite
   MOV   R4,#1
   LCALL   LCD_DWrite
   MOV   R4,#21h
   LCALL   LCD_CWrite
;Set Address Pointer
   MOV   R4,#1
   LCALL   LCD_DWrite
   MOV   R4,#8
   LCALL   LCD_DWrite
   MOV   R4,#24h
   LCALL   LCD_CWrite
   CLR   P2.3
;Output
   MOV   R4,#25h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#41h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#54h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#0
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#33h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#48h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#49h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
   MOV   R4,#54h
   LCALL   LCD_DWRITE
   MOV   R4,#0C0h
   LCALL   LCD_CWrite
END_LOOP:
   SETB   P2.4
   MOV   R4,#09Ch
   LCALL   LCD_CWrite   ;DISP ON
   LCALL   LDELAY
   LCALL   LDELAY
   LCALL   LDELAY
   LCALL   LDELAY
   CLR   P2.4
   MOV   R4,#090h
   LCALL   LCD_CWrite   ;DISP OFF
   LCALL   LDELAY
   LCALL   LDELAY
   LCALL   LDELAY
   LCALL   LDELAY
   JMP   END_LOOP
Clear_Graphics:
   MOV   R4,#Graphic_Low   ;Set Address Pointer
   LCALL   LCD_DWrite
   LCALL   LCD_DWrite
   MOV   R4,#24h
   LCALL   LCD_CWrite
   mov   R7,#128
   JMP   Clear_Loop
Clear_Text:
   MOV   R4,#Text_Low   ;Set Address Pointer
   LCALL   LCD_DWrite
   MOV   R4,#Text_High
   LCALL   LCD_DWrite
   MOV   R4,#24h
   LCALL   LCD_CWrite
   mov   R7,#16
;   JMP   Clear_Loop
Clear_Loop:
   ;Start Auto Write
   MOV   R4,#0B0h
   LCALL   LCD_CWrite
Clear1:
   mov   R6,#20
Clear2:
   MOV   R4,#000h
   LCALL   LCD_ADWrite
   djnz   R6,Clear2
   djnz   R7,Clear1
   ;End Auto Write
   MOV   R4,#0B2h
   LCALL   LCD_ACWrite
   RET
;-------------------Common LCD Writing Functions-------------------
LCD_ACWrite:
   LCALL   AutoW_Check
   SETB   CD
   SJMP   LCD_Write
LCD_ADWrite:
   LCALL   AutoW_Check
   CLR   CD
   SJMP   LCD_Write
LCD_CWrite:
   LCALL   Check_Status
   SETB   CD
   SJMP   LCD_Write
LCD_DWrite:
   LCALL   Check_Status
   CLR   CD
;   SJMP   LCD_Write
LCD_Write:
   SETB    LRD
   MOV   Data_Bus, R4
   NOP
   CLR   CE
   CLR   LWR
   SETB   LWR
   SETB   CE
   RET
Check_Status:   ;Returns once status is okay
   SETB   LWR
   SETB   CD
   SETB   LRD
CS_1:
   MOV   Data_Bus, #0ffh
   NOP
   CLR   CE
   CLR   LRD
   NOP
   NOP   ;CHECK TIMING
   MOV   A,Data_Bus
   SETB   LRD
   SETB   CE
   MOV   R3,#03
   ANL   A,R3
   CJNE   A,#03h,CS_1   ;Switch if function shouldn't loop until status is ready
   RET
AutoW_Check:
   SETB   LWR
   SETB   CD
   SETB   LRD
ACS_1:
   MOV   Data_Bus, #0ffh
   NOP
   CLR   CE
   CLR   LRD
   NOP
   NOP   ;CHECK TIMING
   MOV   A,Data_Bus
   SETB   LRD
   SETB   CE
   MOV   R3,#08
   ANL   A,R3
   CJNE   A,#08h,ACS_1   ;Switch if function shouldn't loop until status is ready
   RET
LCD_DBWrite:   ;writes a section of data starting at dptr to #01AH
   CLR A
   MOVC A,@A+dptr
   CJNE A,#01AH,LCD_DBWrite1   ; #01AH can be changed to any value
   RET
LCD_DBWrite1:
   MOV R4,A
   LCALL LCD_DWrite
   INC dptr
   MOV B,#2d
   LCALL DELAY   ; 1ms delay
   SJMP LCD_DBWrite
; Value in B determines delay length, which is ~ B/2 milliseconds
;Time for Delay is .5ms * B
DELAY:                  ;STORE OUTER LOOP
DELAY2: MOV     A,#0F8H           ;SETUP FOR INNER LOOP
   NOP
   NOP
   NOP
   NOP
DELAY1: DEC     A                 ;1 cycle, delay1 is 2us per loop
   NOP         ;1 cycle
   JNZ     DELAY1            ;2 cycles
   DEC   B      ;1 cycle
   MOV     A,B             ;1 cycle
   JNZ     DELAY2           ;2 cycles OUTER LOOP UNTIL ZERO
   RET          ;2 cycles
LDELAY:
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   MOV   B,#250
   LCALL   DELAY
   RET
Message1:
   db 'Test'
   db 01Ah
END_JMP:
END
PostPosted: Thu Aug 04, 2005 14:28
I don't have time to go through all the steps in your code unfortunately but if you haven't seen it before there is some example code posted here. Maybe it helps.
http://forum.lcdinfo.com/viewtopic.php? ... ght=t6963c
