It is currently Tue Nov 10, 2026 11:18
 Post subject: Crystalfontz LCD help
PostPosted: Fri Sep 23, 2005 20:27
hi
i am new to graphic lcdsand have bought the CFAG160x160 Crystalfontz Graphic LCD Module
i am interfacing it to a Atmel ATMEGA 32 microcontroller
i basically just need to have it display text using the internal character generator
i have started to write code for it in C but have run into many problems. All i have on the screen is a few vertical lines.
here is a bit of my code for the mode control
void modecontrol(void)
PORTC = 0x00; //write 00H into instruction reg//
PORTA |= 0x08; //RS=1 instruction
lcdenable();
busyflag();
PORTC = 0x30; //display on, master, Char Mode, Built-in CG//
PORTA &= ~0x08; //RS=0 data
lcdenable();
busyflag();
void lcdenable(void)
PORTA &= ~0x02; //Enable pin low//
asm volatile ("nop");
PORTA |= 0x02; //Enable pin high//
any help would be great, thanks
Steve
PostPosted: Thu Mar 16, 2006 22:23
steveszol,
Your lcdenable() routine is not corect.
when sending data to the LCD you need to put the data on the bus and then bring E high then low. you have it the other way arround.
P.S. i dont know what xtal your running the Mega32 at but i would give quite a bit more delay so that you leave the E line high longer than 1 nop time length. start out with 1ms i know its a long time but that will rule out one possible problem anyway. you can allways shorten your delays later after you get it working properly.
Good luck!
Jim
