It is currently Wed Nov 11, 2026 2:55
PostPosted: Fri Aug 22, 2008 19:39
hi,
i have a nokia 6610/6100 lcd with philips controller(it has big contacts at the backside) . i am interfacing it with atmega32 at 1mhz and jtag disabled. i am using winavr WinAVR 20080430.
this is the code for making a multicolour box at the center of lcd.
please help me and correct this code i write(or say modified from the codes available on internet) ----
#include <avr/io.h>
#include <util/delay.h>
#define F_CPU 1000000UL
#define SPIPORT PORTB
#define SPIDDR DDRB
#define CS 2
#define SDA 3
#define RESET 4
#define CLK 5
#define cbi(reg, bit) (reg&=~(1<<bit))
#define sbi(reg, bit) (reg|= (1<<bit))
#define CS0 cbi(SPIPORT,CS);
#define CS1 sbi(SPIPORT,CS);
#define CLK0 cbi(SPIPORT,CLK);
#define CLK1 sbi(SPIPORT,CLK);
#define SDA0 cbi(SPIPORT,SDA);
#define SDA1 sbi(SPIPORT,SDA);
#define RESET0 cbi(SPIPORT,RESET);
#define RESET1 sbi(SPIPORT,RESET);
#define byte unsigned char
byte n=0;
byte s1,s2;
byte r,g,b;
void sendCMD(byte cmd);
void sendData(byte cmd);
void shiftBits(byte b);
void setPixel(byte r,byte g,byte b);
void waitms(int ms)
  int j;
  for (j=0;j<ms;j++)
   _delay_ms(1);
int main (void)
  int i;
  DDRB = 0xFF;
  SPIDDR=(1<<SDA)|(1<<CLK)|(1<<CS)|(1<<RESET); //Port-Direction Setup
//hardware reset
  CS0
  SDA0
  CLK1
  RESET1
  RESET0
  waitms(10);
  RESET1
  CLK0
  SDA1
  CLK1
  waitms(10);
 //Software Reset
  sendCMD(0x01);
 //Sleep Out
  sendCMD(0x11);
  //Set Constrast
  sendCMD(0x25);
  sendData(0x3F);
 //Booster ON
  sendCMD(0x03);
  waitms(10);
 //Display inversion on
  sendCMD(0x21);
 //Normal display mode
  sendCMD(0x13);
 //Data order
  sendCMD(0xBA);
 //Memory data access control
  sendCMD(0x36);
 //Colour 8 bit
  sendCMD(0x3A);
  sendData(2);
 // setup color lookup table
  sendCMD(0x2D);
  sendData(0);     // red 000 value
  sendData(2);     // red 001 value
  sendData(5);     // red 010 value
  sendData(7);     // red 011 value
  sendData(9);     // red 100 value
  sendData(11);    // red 101 value
  sendData(14);    // red 110 value
  sendData(16);    // red 111 value
  sendData(0);     // green 000 value
  sendData(2);     // green 001 value
  sendData(5);     // green 010 value
  sendData(7);     // green 011 value
  sendData(9);     // green 100 value
  sendData(11);    // green 101 value
  sendData(14);    // green 110 value
  sendData(16);    // green 111 value
  sendData(0);     // blue 000 value
  sendData(6);     // blue 001 value
  sendData(11);    // blue 010 value
  sendData(15);    // blue 011 value
 // nop
  sendCMD(0x00);
 //Display On
  sendCMD(0x29);
 //Column Adress Set
  sendCMD(0x2A);
  sendData(0);
  sendData(131);
 //Page Adress Set
  sendCMD(0x2B);
  sendData(0);
  sendData(131);
 // write some stuff (background)
  sendCMD(0x2c);
  for (i = 0; i < 18000; i++)
    sendData(28);  // 28 is green
   waitms(200);
       // draw a multi-colored square in the center of screen
  for (i = 0; i < 4096; i++){
    setPixel(i, (i % 64) + 32, (i / 64) + 32);
  while(1==1)
  // now add here your code
 void shiftBits(byte b) {
  CLK0
  if ((b&128)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&64)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&32)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&16)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&8)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&4)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&2)!=0) SDA1 else SDA0
  CLK1
  CLK0
  if ((b&1)!=0) SDA1 else SDA0
  CLK1
void setPixel(unsigned char color, unsigned char x, unsigned char y)
  x += 2;                  // for some reason starts at 2
  sendCMD(0x2B);   // page start/end ram
  sendData(x);
  sendData(132);
  sendCMD(0x2A);   // column start/end ram
  sendData(y);            // for some reason starts at 2
  sendData(131);
  sendCMD(0x2C);    // write some shit
  sendData(color);
//send data
void sendData(byte data) {
  CLK0
  SDA1                                                 //1 for param
  CLK1
  shiftBits(data);
//send cmd
void sendCMD(byte data) {
  CLK0
  SDA0                                                 //1 for cmd
  CLK1
  shiftBits(data);
my configuration is ----
1 VDD 3,3V
2 Reset ------------- PORTB4
3 SDATA ------------ PORTB3
4 SCLK ------------ PORTB5
5 CS ------------ PORTB2
6 VLCD 3,3V
7 NC
8 GND
9 LED-
10 LED+ (6V)
11 NC
 Post subject: example with atmega32
PostPosted: Sat Jan 17, 2009 20:04
just use the schematic here, and the following crystal :) , the LCD itself need <15ns rise time and approx 6Mhz clock frequency for the SPI so 1 Mhz crystal doesn't enough to drive the LCD :( .
http://my.opera.com/kuriel/blog/2008/09/08/menggunakan-lcd-nokia-6610-sebagai-penampil-gambar-berwarna
sorry if my article not in english :lol:
