| CODE FOR CFAG12864B-TMI-V http://forum.lcdinfo.com/viewtopic.php?f=9&t=228 |
| Author: | MYSTICALYUTE [ Tue Apr 29, 2003 6:39 ] |
| Post subject: | CODE FOR CFAG12864B-TMI-V |
IM USING A MOTOROLA BOARD AND IM INTERFACING IT TO THE CFAG12864B-TMI-V LCD BUT MY PROGRAM IS NOT WORKING ANY AT ALL HELP!!!!!!!!!!!!! THIS IS WHAT I GOT SO FAR REGBAS EQU $1000 PORTC EQU $3 PORTA EQU $0 DDRC EQU $7 ORG $100 JSR DISPON JSR DISPSL JSR SETSTP JSR STYADR HERE BRA HERE DISPON LDX #REGBAS BSET DDRC,X %11111111 ;SET ALL PORTC PINS FOR OUTPUT LDAA #%00000000 STAA PORTA,X LDAA #%00111111 ;TURN DISPLAY ON STAA PORTC,X RTS DISPSL LDX #REGBAS BSET DDRC,X %11111111 ;SET ALL PORTC PINS FOR OUTPUT LDAA #%00000000 STAA PORTA,X LDAA #%11000000 ;SETS STARTLINE TO 0 STAA PORTC,X RTS SETSTP LDX #REGBAS BSET DDRC,X %11111111 ;SET ALL PORTC PINS FOR OUTPUT LDAA #%00000000 STAA PORTA,X LDAA #%10111000 ;SETS STARTPAGE TO 0 STAA PORTC,X RTS STYADR LDX #REGBAS BSET DDRC,X %11111111 ;SET ALL PORTC PINS FOR OUTPUT LDAA #%00000000 STAA PORTA,X LDAA #%01000000 ;SETS Y ADDRESS TO 0 STAA PORTC,X RTS WRDATA LDX #REGBAS BSET DDRC,X %11111111 ;SET ALL PORTC PINS FOR OUTPUT LDAA #%01000000 STAA PORTA,X LDAA #%01001000 ;SETS DATA TO 46 STAA PORTC,X RTS STREAD LDX #REGBAS BSET DDRC,X %00000000 ;SET ALL PORTC PINS FOR INPUT LDAA #%00000000 STAA PORTA,X LP: LDAA PORTC,X ;CHECK IF BUSY BRSET PORTC,X %10000000 LP RTS |
| Author: | stef [ Fri Jul 11, 2003 16:41 ] |
helloooo , i don't know too much the motorola , but i don't understand your "main" program ( i know doen't exict in assembler) if i read your prog step by step : org $100 -> go to address 100 in rom prg ( ok ) JSR DISPON -> jump to dispon function (RTS mean return ?) JSR DISPSL JSR SETSTP JSR STYADR -> here problem , what do you do after ? i think you have to make infinit loop to not read again dispon . stop me if i have wrong . as well , you have to send "display on" went you want display the data in memory and went the data are ready in memory . try to check the busy bit between all function . i am may be completly wrong , tell me . |
