It is currently Fri Oct 16, 2026 17:29
PostPosted: Sun Nov 18, 2007 1:48
Hi ,
I'm tring to write programe to interface Fordata LCD module :FDCC0802C
which has KS0066U controller.
I connected the RS E and W/R lines to each pins of one avalable port on my uC (MEGA128 ) and the data pins to another spare port.
I refered to the initialization sequence and used the following init process:
lcd_data=portd;
void lcd_init(void)
porta=((0<<RS) | (0<<EN) | (0<<RW));
lcd_data = 0x3c;
delay 40ms;
lcd_data = 0x0f;
delay 40us;
lcd_data = 0x01;
delay 40us;
lcd_data = 0x06;
void strob()
porta=(1<<en);
dealy40ms;
porta=(0<<en);
void lcd_write()
lcd_data =c;
strob;
void lcd_puts()
porta=(1<<RS);
while(*s)
lcd_write(*s++);
It seams that i am missing somthing on the init process because the lcd is still not working.
Anyone how is familier with these modules?
PostPosted: Sun Nov 18, 2007 15:36
How have you connected the contrast pin ? Are you sure your contrast should be ok.
PostPosted: Sun Nov 18, 2007 17:28
The contrast pin is getting 0v at init process and is connected to one of porta pins. i will try to verify its phisical connection but i am doubt it is not well.
I am affraid that the problem is with the write timing sequence .
http://www.fordata.cn/pdf/short/fdcc0802c.pdf
PostPosted: Mon Nov 19, 2007 20:58
OK , That was quit funny ...
Now the contrast pin is fine vdd and not 0v as i imagened :-(
But still no response from the LCD.
